ok heres the mods
95 pontiac gtp 3.4l dohc
light weight lifters
6/6 cam timing
ported heads
ported to match up and low intake manifolds
msd ignition
magnecore wires
ac delco plugs
38lb injectors
p1sc procharger 7psi
bf intercooler
3inch exhaust
alky control kit (not installed)
ok heres my problem. last year it started to hesitate when on full throttle, Mind you didn't have any of the supercharger stuff hooked up. than I noticed the vacuum line to the fpr was burnt through, so I parked it for the winter. this year I put a new fpr on and the supercharger kit. I went and started it and everything seemed to be running fine. I went and drove it and it hesitated. so I took off the supercharger and was going to wait to get it to the tuning shop first. I drove it without the supercharger on and it was worse by that point. it wouldn't go at 3/4 to full throttle from a stop and when rolling it would just rev high with no power. we checked all sensors and they tested fine. we checked spark and cylinder order and everything is ok there. we rest the prom chip and check the maf sensor and still the same. I can't figure it out. I was going to do a compression check but haven't got to it yet, also checked the fuel rail from a stop and fuel pressure is good, but didn't check it from a load on the car or check the fuel pump. please somebody give me good advice, not even my computer guy could figure out what was wrong.
6/6 cam timing
ported heads
msd ignition
magnecore wires
ac delco plugs
38lb injectors
bf intercooler
3inch exhaust
