96 heads on a 94 engine?????
  • dohcfiend
    King Chalupa
    • Jan 2004
    • 2351
    i am o so close to getting some 96 heads ex manifolds(i won't put them on right away though, i will save my $$$ and get the worked ova first ). but be4 i get them. i have 1 question left from that lengthy post i had about heads,cams,and lifters.
    we all know that pre-96 have a higher compression height on the pistons. couple that with the smaller chambers. and u got a little compression going. the main reason i want 96 heads cause of the revisions made and the better flow characteristics i have heard about.
    the question i have is: if u put 96 heads on say a 94 engine, is the difference in compression height on the pistons going to cause any problems with this swap?
  • dykz34
    • Jan 2004
    • 793
    I don't think it would cause any problems. The gain in compression won't be phenomenal. You would see 9.7:1 or so vs. the 9.25:1 that you have now.
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      no interference with the taller pistons?sweet.
      • Gemmer
        • 240
        Youll have to do everything though, cam carriers and whatnot
        • dohcfiend
          King Chalupa
          • Jan 2004
          • 2351
          true ex manifolds, but why not 94 carriers?
          • Gemmer
            • 240
            Its possible my memory is failing me, but isnt one shorter than the other?
            • Gemmer
              • 240
              oh wait, I just thought about what I said and it wouldnt matter cause its not like you are using the internals from the 96 banks/carriers...
              Hmmm, so I guess a better question would be do the 94 valves fit the 96 heads properly.
                • 13534
                They are the same size valves. GM redesigned the exhaust valve heads but I wouldnt use them anyway. Im not sure the 96 heads flow better either, has anyone flowed them yet?
                • Gemmer
                  • 240
                  if they have, they havnt posted here yet
                  • dykz34
                    • Jan 2004
                    • 793
                    Ya, this project is probably not worth the trouble.
                    • BowtieKid79
                      • 59
                      I've got a VERY low mileage set of 96 heads if anyone is interested. PM or email me if you are interested.
