Best Manual Tranny
  • zog09
    • Nov 2009
    • 39
    Best Manual Tranny
    Which would be the best manual transmission that can bolt up to my '95 cutlass supreme 3.4L 24V V6?
  • SofaKingWeToddDid
    • Jul 2009
    • 785
    getrag
    • zog09
      • Nov 2009
      • 39
      Originally posted by SofaKingWeToddDid View Post
      getrag
      So it will bolt up to my car's LQ1 engine. I was thinking about maybe getting that kind of tranny for it. But i wasn't sure if it would bolt up.
        91-93 W-bodies with the 3.4 could get the getrag 284. it's about the toughest GM 5 speed transaxle there is, but rebuild kits are few and far between, not cheap either.
        • zog09
          • Nov 2009
          • 39
          What about '95 w-bodies? What would be the best choice of manual transmissions for them?
          • Smittro
            • Aug 2009
            • 94
            There was no manual trany available for w-bodies after 93' all auto's..
            • zog09
              • Nov 2009
              • 39
              What if I get someone to customize it for me?
                95 still got the generation 1 firewall plate, so fabbing up the necessary stuff to convert it to a manual isn't too tough. it's been in my plans for years, just the funding never came up.
                • zog09
                  • Nov 2009
                  • 39
                  Sweet. How much did you estimate that it would cost to convert to manual?
                    depends on how much labor you do yourself.
                    i had the opportunity to buy all parts necessary for the conversion for about ~300 a couple of years ago. unfortunately, i ran into some other issues that prevented me from going through with it(mainly, not being within 2500 miles from home for about 1 1/2 years).
                    • zog09
                      • Nov 2009
                      • 39
                      What tranny were you going to use?
                        i was going to use a 282 from a 88-90 W-body (probably a grand prix). but a 284 is EXTREMELY similar, just beefier.
                        • zog09
                          • Nov 2009
                          • 39
                          How much hp can a 282 handle? And how much can a 284 handle?
                            depends on quite a few things: weight, torque curve, tires, use of a LSD, clutch, etc...
                            heads up: torque kills trannies, not HP.
                            but there are 282s that have built to withstand quite some abuse. superdave has his 3500 Z24 putting down 275WHP and pulls a flat 13 seconds. granted that's a much lighter car than any W, but it's an example.
                            something else that has become an option as of ~2006: the F40. that's the six speed tranny used in the G6 with the 3900. the only real issue with it is the dual-mass flywheel, which some have compllained about. GPChris has one swapped into his 95(or 96, i can't remember) grand prix, with a LQ1, so it would be an identical swap for you to copy. that tranny really hasn't been pushed to it's limits yet, so no one is really sure what it's capable of. i believe V8-Archie has used it in some LS swaps in fieros...
                            • zog09
                              • Nov 2009
                              • 39
                              Whats a dual-mass flywheel?
