Which would be the best manual transmission that can bolt up to my '95 cutlass supreme 3.4L 24V V6?
Best Manual Tranny
91-93 W-bodies with the 3.4 could get the getrag 284. it's about the toughest GM 5 speed transaxle there is, but rebuild kits are few and far between, not cheap either.
What about '95 w-bodies? What would be the best choice of manual transmissions for them?Originally posted by robertisaar View Post91-93 W-bodies with the 3.4 could get the getrag 284. it's about the toughest GM 5 speed transaxle there is, but rebuild kits are few and far between, not cheap either.
95 still got the generation 1 firewall plate, so fabbing up the necessary stuff to convert it to a manual isn't too tough. it's been in my plans for years, just the funding never came up.
Sweet. How much did you estimate that it would cost to convert to manual?Originally posted by robertisaar View Post95 still got the generation 1 firewall plate, so fabbing up the necessary stuff to convert it to a manual isn't too tough. it's been in my plans for years, just the funding never came up.
depends on how much labor you do yourself.
i had the opportunity to buy all parts necessary for the conversion for about ~300 a couple of years ago. unfortunately, i ran into some other issues that prevented me from going through with it(mainly, not being within 2500 miles from home for about 1 1/2 years).
What tranny were you going to use?Originally posted by robertisaar View Postdepends on how much labor you do yourself.
i was going to use a 282 from a 88-90 W-body (probably a grand prix). but a 284 is EXTREMELY similar, just beefier.
depends on quite a few things: weight, torque curve, tires, use of a LSD, clutch, etc...
heads up: torque kills trannies, not HP.
but there are 282s that have built to withstand quite some abuse. superdave has his 3500 Z24 putting down 275WHP and pulls a flat 13 seconds. granted that's a much lighter car than any W, but it's an example.
something else that has become an option as of ~2006: the F40. that's the six speed tranny used in the G6 with the 3900. the only real issue with it is the dual-mass flywheel, which some have compllained about. GPChris has one swapped into his 95(or 96, i can't remember) grand prix, with a LQ1, so it would be an identical swap for you to copy. that tranny really hasn't been pushed to it's limits yet, so no one is really sure what it's capable of. i believe V8-Archie has used it in some LS swaps in fieros...
Whats a dual-mass flywheel?Originally posted by robertisaar View Postdepends on quite a few things: weight, torque curve, tires, use of a LSD, clutch, etc...
