PwrTuner and 1997 DOHC ?
    i've never seen a 97 MC Z34/Lumi LTZ 3.4 without a 65....
    does that quart over trick apply to all 4T60-E trannies? and potentially even the 4T60?
    • Dave96z34
      • Apr 2005
      • 624
      It should it helps to lesen foam and takes it a lil bit longer to heat soak from drag racing. But Dexron VI would be the best thing you could do for it. Or dish out the cash for the royal purple...
      • jman093
        • Jul 2008
        • 164
        What makes the 97 PCM tuneable and not a 96? They are the same part number, so I take it the software is different?
        Jesse M.
        3x 1990 Turbo Grand Prix
        1987 Monte Carlo SS Aerocoupe
          • 13508
          97 has twice the data tables as 96.
          • Dave96z34
            • Apr 2005
            • 624
            96 is vary tunable but only with the dhp tunner. No they are not the same pcm. If it was I could flash the 96 with a 97 bin but you cant the 96 is vary different.
            • RedZMonte
              • Feb 2004
              • 1378
              #21
              Good to know info.. im actually on the rebuild going to the Dextron 6 fluid. didnt know about the overfilling trick but... Curious to know if the PCM connectors are the same from '96 to '97 and also if the pin-out would have to be changed if they are the same physical connector.. I have a '99 GTP ecu and a '98 LTZ ecu i guess i could look at them and see.
              But from the looks of it i think im just going to rebuild the 60-E... id like a 65-e but honestly its my DD and it has lasted ~147,000 miles completely stock so i guess i aint making enough TQ to break it too bad lol... We will see once she is apart, unless its just TRASHED then i might consider the 65 swap.
              S
              Shane "RedZMonte"
              1992 Lumina Z34-VIRGIN (RIP)
              1992 L67 Lumina Z34 (SOLD)
              1990 Turbo Grand Prix (SOLD)
                if you really want those PCM pinouts and stuff, hit me up with a PM with all possible details and an e-mail address to send them to.
                • pontiacjeff
                  • Jun 2004
                  • 147
                  #23
                  I switched my 96 Bonne, I believe there are about 7-10 wires that need to be relocated, and then you need to add the extra wires for the -65 if you intend to use it. I am a GM tech now, so I can get you connector views and pin charts.
                  Jeff Ianitello
                  Engineered Performance
                  Atlanta, GA.
                  • RedZMonte
                    • Feb 2004
                    • 1378
                    #24
                    Werd! i won't put you threw the trouble as of yet... Im gunna see what the damage will be before i ask for you to go threw the trouble.
                    S
                    Shane "RedZMonte"
                    • jman093
                      • Jul 2008
                      • 164
                      #25
                      Oh you're right about the PCM, I looked it up and they are different numbers. Here's what I show:
                      96 Z34 - 88963800
                      97 Z34 - 19109047
                      96 GTP - 16217058
                      96 Cutlass 3.1L and 3.4L - 88963800
                      97 Cutlass - 16217058
                      97 GP - 16217058
                      97 GTP - 19109047
                      98 Monte, 98 GTP - some completely different number than the 96-97's
                      I'm still confused though. Can/Do you put a 96 bin in a 97 PCM and then tune that? Seems to me like you'd have to have the right year and model software in the later PCM to make it run right. 97 GTP's have a very different engine and a 4T65-E and even the 97 Z34 has the 4T65-E (I just learned in this thread) so the software would be way different than a 96 GTP/Z34. Doesn't seem like it would work otherwise.
                      Jesse M.
                      • Dave96z34
                        • Apr 2005
                        • 624
                        #26
                        You use a 97 bin when you swap to the 4t65.
                        • jman093
                          • Jul 2008
                          • 164
                          #27
                          But what about keeping a 4T60. Does a 96 bin work in a 97 PCM?
                          Jesse M.
                          • RedZMonte
                            • Feb 2004
                            • 1378
                            #28
                            doubt it.. 1996 bin i think only works on the 96 pcm... someone can verify this... but i think its completely different pcm.
                            Shane "RedZMonte"
                              No, you need to use the proper bins for the proper ECM's. 96 is a 256k file, 97's are 512k so they will not work. Also you can use a 97 ECM to control a 60e. I'm doing it right now. All the shift controls are essentially the same since for the 60e all it will use are the shift tables, and tcc lockup tables, the rest is ignored such as the shift time and shift pressure, well not really ignored but since the wires are not connected it will not affect how the 60e shifts.
                              • RedZMonte
                                • Feb 2004
                                • 1378
                                #30
                                Good to know... maybe i will track down a '97 PCM or see if i have the correct PCM in hand i can flash with the '97 info and if this trans fails again put in a 65e...
                                S
                                Shane "RedZMonte"
