Phenolic Plenum to Lower intake Manifold Spacer-3.
  • d.o.h.c
    • Jun 2004
    • 981
    This is a Phenolic Spacer that goes between the Plenum (Upper intake manifold) and the Lower intake manifold. The goal of this spacer is to keep the heat from soaking into the intake air from the engine. The IAT's with the Plenum run around 150 degrees, this spacer drops the IATs to 100
    Mark
    Price: $69.99
    Pics:
  • mrl390
    • Jan 2008
    • 132
    Neat idea. Do those act as gaskets or will you need a gasket on both sides of the spacer?
    -Matt
      • 13522
      where did you put the iat to get those readings? 50% efficiency from that thin of a piece, plus coolant still flowing through the throttle body leaves me scratching my head. What was the ambient temp?
      • d.o.h.c
        • Jun 2004
        • 981
        We used a digital thermometer.
        • d.o.h.c
          • Jun 2004
          • 981
          Yes, its just a barrier item to keep the head from heating the intake manifold.
          Mark
          • GTP091
            • Jun 2005
            • 232
            where did you put the iat to get those readings? 50% efficiency from that thin of a piece, plus coolantsee still flowing through the throttle body leaves me scratching my head. What was the ambient temp?
            I'm with Ben on this. It may keep the temps low for a bit longer than normal after startup but the coolant going through the throttle body will still heat soak the intake and you'll be right back where you started. You could bypass the throttle body line....
            Did you measure after startup or a long cruise?? was the throttle coolant line bypassed?
