Injectors maxed out or fuel pump?
  • poncho racing
    • Aug 2011
    • 17
    Hello I have a Turbo'd 3.4 dohc with #67 injectors and a 255 walbro. My Injector duty is at 87% i'm wondering if this could be caused by the fuel pump? I'm only making 370 hp and 330 torque at 13 pounds of boost. oh and this is also on E-85.
  • timg
    • Feb 2004
    • 718
    Does your fuel pressure drop off toward redline? If so, that points toward the fuel pump. If not, it points to the injectors. Realistically, it could be either as you're close to the limits of the Walbro and the 67# injectors (when running E85). If you want more flow, the Aeromotive 340 or Walbro 416 (E85) pump are good options.
    Have you tried re-wiring your fuel pump?
    Tim
    325 whp 350 lb-ft
    • poncho racing
      • Aug 2011
      • 17
      The place I took it to said that the fuel pump and injectors are about maxed out. I planned on getting the 416 walbro anyways but you are the first one to say that my 67# injectors are close to there limits. Everyone else says that there plenty big. And i have seen LQ1 make well over 400hp with just 42#'S
      • RedZMonte
        • Feb 2004
        • 1378
        67# injectors and E85 on 13psi is about it.. the 3800 guys are running 80+ lb injectors with E85. i agree with timg.
        Shane "RedZMonte"
        1992 Lumina Z34-VIRGIN (RIP)
        1992 L67 Lumina Z34 (SOLD)
        1990 Turbo Grand Prix (SOLD)
        • poncho racing
          • Aug 2011
          • 17
          Also could the custom ground cams make an effect on why i'm not making the power I should be? Does anyone know how much I should retard the cams?
          Thank you
          Steve
          • RedZMonte
            • Feb 2004
            • 1378
            different cams will definatly change your performance... what are the specs of the cams? and are they set to stock timeing or are they advanceed/retard? the more info about your setup the better. What Turbo (size as well as AR&Trim), what manifolds, cam specs, how much timing are you running? your tune could also be a major limiter of your hp. are you running OBDI or OBDII? Auto Trans or Manual? anything you can tell us about your setup will help....
            Shane "RedZMonte"
            • poncho racing
              • Aug 2011
              • 17
              I'm not sure what the specs are on the cams. They are retarded but i'm not sure how many degree's. All I can tell you is the guy had them made for a N/A car and kept them in after boosting. Its a Turbonetic T3/T4 T-62 trim with a stage 5 wheel and .63 A/R . Stock Manifolds, not sure what its running for timing. Engine mangaged by a Haltech E6k and Its a 5 spdl.
                • 13522
                Your injectors will support more hp with E85 than you are getting, but I am not sure if the pump itself is the issue. Cam timing and tuning will matter as well.
