Going for 300whp NA
  • 02dohc
    • Sep 2009
    • 105
    With 11 to 1. I should still be able to run non oxygenated 93 octane, if I go outside the Midwest e85 is hard to come by
    Sent from my MB886 using Tapatalk
      I've had my trans shift at 6,750. The commanded shift point was lower but 1-2 is ALWAYS delayed from the commanded RPM.
        yours trans is noticably different from stock.... i'm sure a lot of GM's specs/requirements are going to differ from reality at that point.
        i don't know what is the basis for the 6,250RPM recommendation though... whether some number the engineers threw out or some specific part not being able to handle speeds higher than that.
        • 02dohc
          • Sep 2009
          • 105
          From what I got from zzp the pump shaft and pump are only good enough to hold the 6,200 rpm. Cause zzp offers a hardened shaft and different pump and they said it will hold well over 7,000 rpm shift points
            what is max lift on those heads?
            • 02dohc
              • Sep 2009
              • 105
              #21
              I have to ask Ben what his springs will do for lift and where coil bind is. I will hopefully be ordering them the first part of next month
                I'd love to see what they claim is a different pump because the pump is extremely basic... not much can be changed other than inlet slot design and or the spring used to cushion the housing. It's also 4t65e specific I'm sure...
                • SwiftDrift
                  ...But what if-
                  • Dec 2013
                  • 204
                  #23
                  How good does the intake flow on the dohc? Like compared to a 3400/3500? Sorry i just didnt want to make a whole new post on it
                  Firebird: The beta version
                  • 02dohc
                    • Sep 2009
                    • 105
                    #24
                    What size injectors would u think would work with the explained build. Just looking to get within the ballpark. I will be running e85.
                    I just don't know if 42.5lb injectors would be overkill
                    • caffeine
                      • Jan 2012
                      • 1489
                      #25
                      For 300whp I don't think they would be overkill with E85
                      '86 Fiero, 3500, 4-speed
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        #26
                        food for thought, stock DOHC with similar cams did about 230 whp.
                        http://www.fiero.nl/forum/Archives/A...-064798-3.html
                        would a 3500 crank swap in? is so, you could have one offset ground and pick up a good bit of displacement with it.
                        • 02dohc
                          • Sep 2009
                          • 105
                          #27
                          I don't know how much more stroke u could out in it with already being an interference motor and have high compression pistons. I have read that thread and that is what got me thinking that 300 wasn't that far out of a goal like every one else thinks.
                          • ericjon262
                            build it.
                            • Jan 2010
                            • 2218
                            #28
                            interference only has to do with cam timing and piston to valve clearance, not a thing with stroke.
                            • caffeine
                              • Jan 2012
                              • 1489
                              #29
                              Increasing stroke just means you need shorter pistons to avoid pistons smacking the heads.
                                if he already has new pistons(and it sounds like it), that would require selling/tossing those.
