Going for 300whp NA
  • 02dohc
    • Sep 2009
    • 105
    #91
    An itb intake is also in the works for the 3.4 Dohc in my fiero
      i've read a hundred people's threads claiming to have them in the works but never following through.
      please be the exception to the rule, i REALLY want to see how the LQ1 reacts to ITBs.
      • 02dohc
        • Sep 2009
        • 105
        #93
        Well I have six extrudabody 52mm to 50mm taper bore throttle bodies and the flange is already cut to bolt to the lower manifold. I'm going to criss cross them three above each valve cover. And then run two plenums with a filter under each "over roof scoop" of the fiero
        • timg
          • Feb 2004
          • 718
          #94
          Unfortunately, the VW head stud kit I found didn't work on the 96 heads I have. I suspect that any head stud kit would require someone to make all of the required measurements and then order directly from ARP or someone else. IIRC, one of the Fiero guys was using a head stud kit he pieced together.
          Tim
          325 whp 350 lb-ft
            • 13520
            #95
            Tim
            We have head studs but you can't use washers with them.
            Deja Vu
            • ericjon262
              build it.
              • Jan 2010
              • 2218
              #96
              anything new here?
              • mrsleeve91
                • Jul 2006
                • 37
                #97
                I used raceware's head studs for a M20 BMW, I had to call and order to get an extra 4 studs (and nuts and washer) as I recall. And I had to shorten them .200" to clear the cam carriers.
                Fiero gt 3.4 DOHC turbo forged bottom end MSII
                94 Ranger 2.3 turbo t5 (DD)
                  • 13520
                  #98
                  We sell M20 head studs, and they won't fit a 60V6 block. M10 vs M11.
                  • mrsleeve91
                    • Jul 2006
                    • 37
                    #99
                    My apologies, I recalled wrong.. special ordered...Click image for larger version
                    • carbon
                      Procrastinator
                      • 388
                      #100
                      anything new here?
                      He's still working on it, but he's looking at moving a couple of hundred miles away and trying to figure out what to do with all his junk... LOL
                      - Ben
                      • 02dohc
                        • Sep 2009
                        • 105
                        #101
                        Thanks nick. Yes I am still working on it. As of now this is where it stands. I have put the motor into my Fiero and hooked a getrag 282 5 speed to it that has a ep LSD in it.
