TB/Plenum Replacement
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    I doubt if I do it untill the car becomes"Tunable", but what knd of options are available for doing away with the 1 piece TB/Plenum on the 94, 3.4?
    • 13531
    96 swap, or do what im doing and modify the stock plenum:P
    • RednBlack
      Wood Hippie
      • Mar 2004
      • 2795
      I had discussed this with cncguy, the cut and modify, adding a flange..You will document and post this?
      • dohcfiend
        King Chalupa
        • Jan 2004
        • 2351
        also u can go to a 91-93 plenum, i believe their tb's are removable. as far as i can tell it is about a direct bolt up swap, probably won't even need to change the lim. don't know for sure though.
        dude, u are in ohio? perhaps u and sappy should get together and do something with that 94 chip u have.
        • Anonymous
          All 3.4L DOHC upper intake manifold plenums/throttle bodies were 1 piece units until the 1996-97 years, when they became 2-piece.
          So he could swap to a 96-97, but it does take some mechanical inclanation to do.
          • RednBlack
            Wood Hippie
            • Mar 2004
            • 2795
            That has been a thwarted plan for a year now..Maybe before too long with this new job.. Then we all can benefit. cncguy has an old beater I can get super cheap..
              • 13531
              When i can afford to finish it I will. Im not gonna go into detail just yet cause I wanna test it, and make sure im the first to do it cause I plan to sell it if it works out well. I just don't know what tuning it will require, especially with MAP. With MAF, it may be pretty easy to change the fuel tables. MAF is pretty consistant unlike MAP.
              • dohcfiend
                King Chalupa
                • Jan 2004
                • 2351
                oops, my bad.
                • dykz34
                  • Jan 2004
                  • 793
                  Wrong! The 96-97's were THREE pieces (plenum, arm, and TB).
                  • blk92z34getrag
                    • 515
                    --Rob
                    • Anonymous
                      I knew that and you should have known that I knew that
                      But yah you're right, I just wasn't thinkin.
                      I was owned
                      • dykz34
                        • Jan 2004
                        • 793
                        Don't tempt me...
                        • Anonymous
                          I knew putting that smiley up would put ideas into your head.
                          Lemme get rid of them....
                          • ez112
                            • 258
                            Can't the intergrated throttle body be ported out? Is that even a good idea?
                            Even though I don't have a 95 below, I know someone that does and is going to have the throttle body ported out...what can he expect to see as far as gains?
                            1999 SVT Lightning
                            1996 Monte Z34 R.I.P.
                            Next BEATER: a C5
                            http://www.fquick.com/ez112
                            • TheProfessor
                              • 869
                              lol chuck norris
                              nice!!!!!!!!!
                              I Like V660s
                              Does Chevy make beer
                              ~Jayme~
