unfortunately i am going to have to put this on back burner for now cause i can't afford the r&d cost right now.
READ: my crazy intake idea
well it is official. this is back on front burner. i have a 98 n* intake coming. i found someone to fab me up a new tb neck to match the tb too(also if it sucks i can put my stock stuff back on).
bracketry is np. only thing i am concerned about is sensor compatability. i will make a seperate post to stir up some info on this.The Official Rotating Mass Nazi
Finally, here are some pics of the new intake arm. all that is left are 2 vac ports to add, a provision for a map sensor, a provision for a nitrous nozzle and final polishing. Too bad aaron got banned, he was all about the high end hp. but i am hoping for a little better throttle response too. idle quality ehhhh i will see. i will keep you guys posted on the end result of this little project of mine.
also i am in the middle of having the lower ported and the inlets ported and matched on the plenum. i have already polished the tb myself and i might have a pic in a day or two. but i see head porting in the near future, b/c if they aren't maxed out they will be as soon as i bolt this stuff on.The Official Rotating Mass Nazi
ok i got off my lazy ass and took a pic. i polished the mouth, the throat, and the shaft. i also modified the plate. Most throttle plates look like waffle irons so i ground down the plate until that design was removed, then i smoothed the edges a little since they were so square but was careful not to change the od of the plate and lastly polished it.The Official Rotating Mass Nazi
BEAUTIFUL work. I definitely want to get one of these if I ever get around to doing the 96-97 intake swap. Nice!
here are some updated pix. i don't see the MAP provision, so i will have to see about that. checked into it, going to do a remote mount later. i am not really worried about it now since my current computer system has no need for it, but when i go obd2/boost later i will have it waiting and ready.The Official Rotating Mass Nazi
also the guy who built it is taking orders and will cut a group rate for 4-5 peeps there is 1 confirmed and 1 semi-confirmed. i won't pull any middleman bullshit with you just pm me and i will give you his number. just tell him bobby sent you, that is all i ask.
i found out today it is a 6 port vac block.
**update i have been politely asked to not give out his number and divert to email instead**The Official Rotating Mass Nazi
UPDATE: i have recieved it and am starting the install.
THE BAD:
well i got started on the thing today. the threads on the itake arm are ok but the threads on the vacuum block are not the same as the 1/4 npt.
and the guy forgot to send the intake arm gasket, so i wil pick it up tomorrow
let me give you the low down so far. that thing is so close it isn't funny. the way the tb is built it almost touches the hood when i close it. i mean less than 5mm!! the intake arm sits right on the dip stick, the brake booster port had to be shortened 2 rings to clear the brake controller, the throttle thing is so close to the abs on the tb i had to hack off the cruise control hookup to make it clear and lastly the nitrous nozzle is so close to the fuel lines where they connect to the rail i will have to put on the nozzle and attach the line one at a time while snaking them through the fuel lines.
lastly i am going remote on the vac block b/c it interfers with the abs. DAMN ABS. it will look better remotely mounted anyway. not i just have to figure out where.
i haven't started on the throttle linkage or seen if my wires are long enough to fit the 2 sensors yet(argh) that will be tomorrow. but that is the things that happen with custom stuff, i couldn't have known and neither could you. even though it is tight it fits and that is what counts. only thing that has me bummed is no cruise control.The Official Rotating Mass Nazi
THE GOOD: but that was the bad and it isn't that bad so far. that motherf**ker looks so mean when i bolted it up to mock fit. u just guys don't know.
i didn't realize the scale on how much larger than biaaatch is. my g/f could fit her arm in it and i could almost shake her hand on the other side.
TOMORROW: my plans for tomorrow include picking up the gasket, begin a bracket for a remote mount, checking wiring/hooking up the sensors, starting on the throttle linkage and begining n20 nozzle mock fit and install. whether the linkage is done or not tomorrow and whether or not i finish with the n20 tomorrow it will be cranked.
tonight i will be cutting gaskets, threading fittings, mock fitting the vac block and making a template for the bracket.The Official Rotating Mass Nazi
I would love to see pics of the bad mother once it's done1991 Lumina Z34 - http://members.sounddomain.com/lcmbear77
1979 El camino (Faster of the two)
FFP Stuff (chip, D Bone, UD pulley)
Custom STB,WAI with K&N, Full Catback with Dual Magnaflows and Rative tips, 3k stall and 3.73 gearing coming soon
UPDATE: i had to help a freind move today so i didn't have alot of time to work on the car or get to the machine shop. but i think i got alot done in the time i had. i re-routed the wires and they plug in and i finished construction on the throttle cable bracket and it is functioning.
THE BAD: my n20 nozzle is so close to my fuel rail i can put any lines on it. i a going to the machine shop tomorrow as well as discuss ideas with the builder
TOMORROW: tomorrow is mostly vacuum day. i am going to the machine shop to fab a bracket for my vacuum block and see if i can resolve this nozzle issue. after i get back i will remove the cruise assy and the ccp assy, then i will re-route the vacuum lines and connect them.
if all goes well i will install the gaskets and start it.
well jj here is a teaser for you. i took a pic of it assembled and if u think it looks viscious here, wait until i get one of it on the car.The Official Rotating Mass Nazi
UPDATE: man i am having a hard time mostly due to random factors. i went to the machine shop. got the mounting bracket fabbed. they had some stainless laying around so i was happy about that.
next the guy at the machine shop fucked up to get the n20 lower he decides to counter sink the threaded hole and as soon as the bit touched it it cought and took out all the threads so i had to wait all day for him to make a sleeve and the does sit lower but not low enough.
it is about 5 and i haven't even started yet. i get the cruise bypassed and the cp bypassed then a friend i haven't seen in forever comes over so i ditc the car b/c he wants to go out.
i finally get back to it i run into a kink i was only expecting 1 vac hose to be going to the firewall after the cc bypass for the heater and alas there are 2. i im about 5 peeps, no help. out of the face of desperation i get an idea i had 2 manuals laying around and i thought "gm puts alot of the same shit in different cars" i consult the 1st one for a caprice, it has fully electronic cruise no help there next i have one for a gen3 firebird and it has vac cruise and it referenced a vac line to the brake pedal to tell the cruise when u hit the brakes. so i look and bam that was it.
got the heater vac hose hooked up, the fpr hose hooked up, the vac modulator hose hooked up.
TOMORROW: the brake booster hose is so tight i will have to get a 90 degree fitting tomorrow to make it work, hook up the source hose for the vacuum block and hook up that hose that goes to the valve cover. i would have done all that today but i didn't have the right size hose.
other than that it is the arduis task of going back to the machine shop to fix this nitrous nozzle problem.The Official Rotating Mass Nazi
