hopefully they have the right tap :P
READ: my crazy intake idea
UPDATE: got the 90 degree fitting and all the vac hoses are straight. nitrous is my only problem left. the machine shop guy grinded down the bung today and it looks like it might clear but the sucky-ass local speed shops here don't carry 3an fitings much less a 90 degree 3an. i am having it overnighted from summit.
TOMORROW: after i get the fitting, i will attempt to fit it if it doesn't the machine shop guy has 1 thing left to try and if it doesn't work i will simply plug the hole for now and eat the cost of that fitting and overnight charges.The Official Rotating Mass Nazi
Originally posted by dohcfiend...90 degree 3an. i am having it overnighted from summit.
Wow... you're impatient... What is that, $17 to ship a $12 fitting?Current:
\'87 Fiero GT: 12.86@106 - too dam many valves; ran 12.94 @ 112 on new engine, then broke a CV joint
\'88 Fiero Formula: slow and attention getting; LZ8 followed by LLT power forthcoming
\'88 BMW 325iX: The penultimate driving machine awaiting a heart transplant
Gone, mostly forgotten:
\'90 Pontiac 6000 SE AWD: slow but invisible
cool project. I won't need a bigger t.b. as I'm going to be boosted. I thouhgt about mounting a big a** t.b. right on the plenum, but the booster is in the way. The intake adapter adds volume to the plenum, too, which is a bonus effect.Jeff Ianitello
Engineered Performance
Atlanta, GA.
DDAY: although i was defeated on the n20 nozzle i just stuck a bolt in the hole for now.
but i cranked it today and took a vid
have a host and the vid is coming. thanx brad
i also took a vid of the engine in stock form to compare but i need a host for it.The Official Rotating Mass Nazi
This is the second link of th eintake BEFORE the new tube. Right click and save as!
sweet
I want one so bad I live about 5 miles from a dyno so I am willing do before and after test if I can get one.
A bigger t.b with no other changes, can cause an off idle stumble. Intake velocity will be reduced at p.t. cruise. A turbo engine doesn't need as big a t.b. b/c the intake air velocity is ALWAYS higher.Jeff Ianitello
Atlanta, GA.
as far as i can tell mine idles fine. but i am sure alot of bottom end went south. i was thinking volume, a bigger tube and tb combined with forced induction will give plenty of velocity i would think. but u are probably right on the off idle stumble i will find out soon enough
well, i dropped it on its wheels today. all i have to do now is wait until monday and i will creep it to the shop and get the cv boot clamps put on. then i will have a road test and a run on the ole ass dyno.
also a couple peeps asked me what my car looks like so this is for u. nothing special just a 94 metallic gray z34. Interior is stock, exterior is stock, rims are stock, stereo is stock bose 6 speaker system, engine and tranny are not stock. I guess you guys can see where my priorities lie
