Coolant Passage Porting
  • dykz34
    • Jan 2004
    • 793
    Is there any way I can port out the passages in the block, heads, and lower intake to help flow more coolant? It should be good for about 15hp at the wheels...
    Sorry guys, had to post another "porting" thread because of all the recent ones!
    • 13533
    Well, I have ported (as aaron would call it cause welding up an oil pan for more capacity is porting) the cam carrier oil drain back holes to remove the casting flash in them. Its good to get the oil back to the pan as quickly as you can Have you noticed how small the holes are or the coolant to flow through in the headgaskets? I was going to match them to the actual passages but was told not to as they were designed that way for the coolant to not flow as well, which would cause hotspots and overheating.
    • firechiken
      • Feb 2004
      • 557
      http://b2b.airgas.com/browse/product...&recIds=111546 This should work! Wish there was a movie of this thing in action! Anyone else here use one of these?
      • Anonymous
        Originally posted by sappyse107
        Well, I have ported (as aaron would call it cause welding up an oil pan for more capacity is porting).
        I just said that cuz I had no other words to use. I know the difference of course. I wasn't really considering it porting, more reengineering.
        • TheProfessor
          • 869
          i got 50 hp at the wheels from porting my coolant passages
          I Like V660s
          Does Chevy make beer
          ~Jayme~
          • dykz34
            • Jan 2004
            • 793
            SWEET!!! I don't know what I've been waiting for then!
            • TheProfessor
              • 869
              you like that????????
              I Like V660s
              ~Jayme~
