Oh yeah, forgot to mention... GRRRRRRRRRRRRRR!
hehe... retarded exhaust cam
Well think of it this way. It's not a 96 or 97, so you won't have any bent valves
hehe... way to look at the bright side.
I just got finished retiming (I can do it in 20 minutes now
and now it seems to run good, I just have a massive vacuum leak causing it to hit the rev limiter... no doubt because of my new short runner intake - which I might just have to have welded up instead of f*cking with silicone and acrylic
Okay now, that's enough of that.
Youre getting knock retard at 17* ??Originally posted by SappySE107It certainly wont have any low end. 17 or whatever I had was so horrible, and the knock retard was crazy. I spent a few days tuning it perfect too and it was still ass. 13 was flawless though for KR...but I gotta tune it still once its back together.
Hmmm... I'm at roughly 16* and havent noticed any pinging, but could be beyond my range of hearing / feeling. Was the KR coming in at high/low rpm, wot only?? Any idea why it was getting KR?
After I did the heads I was plannin on 18* or so. I can't complain about the low end at 16* its still freakishly okay, even with the 96 manifolds. Idle isnt even bad, its just rough compared to before, although if I let it idle for 5 mins or so it gets a mean sounding lope. Down low its not as good as stock, but its not bad and over 2500 it starts to feel better than before and of course after 4k and up to 7k its a big improvement.1991 Grand Prix GTP LX9swap/Getrag 284 --- SOLD =(
1994 Corvette LT1/ZF6
2006 Dodge Dakota 4x4 3.7/42RLE
It was part throttle and WOT, and I couldn't hear it but the scanner showed it.
I had as much low end as you would expect from a DOHC, as the general idea of our low end is. As far as what I thought I should have, it was pathetic. Now with 13 degrees the low end is MUCH better and no KR
I jst retarded my exhaust and intake cams both 13 degrees retartedand the thing is so incredibly fast i also ported and polished my intake and plenum and throtle body and i shaved 3.3 seconds off of my 0-60 time. it has tons of low end and it pulls incredibly hard and it hits high speeds much faster now! i recomend doing both exhaust and intake 13 degrees!GM Goodwrench Tech - GM Certified
if you just did the retard timing, is 265hp and 270 lb-ft from before or after the fact?
Brian
3400 SFI V6, 4T60e
its after, when i say i just did it i mean 2 months ago. I also put bigger exhaust pipes and performance mufflers on it. and im getting a chip in January. Has anybody else tried doing the intake cams? at first it was a mistake that i did both of them but i figured that i would try it and after the first test drive i knew i was keeping it! it has a ton of low end torque and i cant keep the tach needle off the redline. when you put it to the floor you are plastered back in the seat. it idles at 1000 rpm nice and loopy and throatier. it never stalls. it was such a BIG difference in power it was unbelievable!GM Goodwrench Tech - GM Certified
um....yeah. Thats why it ran like ass when I had them at 6 degrees retarded. Retarded timing hurts low end, so im calling bullshit.Ben
WTF?? Dude, you dyno'd your car or are you going RICER on us and estimating!? Bullshit man...
p.s.- Guess we have found the C-REX equivalent from the W-body board on this forum
\"Pree\" - 93 Grand Prix SE - 3.4L Twin Dual Cam
- FFP UD Pulley - FFP Chip - 8mm Taylor Wires
- 160* T/stat - Dual 40 Series Flowmasters
- Hi-Flo Cat
15.2@95mph - GTECH P/B
http://home.rgv.rr.com/tjperformance/Cap0005.mpg
ok im estimating according to people that have done this shit and dyno'd it. if you guys dont believe me ill race anybody on this site.GM Goodwrench Tech - GM Certified
unless the intake cams spin opposite then the exhaust and i advanced the intake cams 13 degrees? because its really fast and tons of low end.GM Goodwrench Tech - GM Certified
Vegeta, wat do you think??
Hey man, why don't you head over to W-Body.com/forum and let the peeps there know all you just told me! PLEAZ!
They will love me for it!!!
- Hi-Flo Cat
