Supercharging the 3.4...
  • PlatinumZ34
    • 232
    Ok well my AC condensor(or compressor, im too stressed to remember the name) decided to start on fire the other day, so i'll be removing my air conditioning system all togethor. Which got me thinking, why dont i stick a supercharger inplace of the AC compressor... Which then made me realise getting the piping to the throttle body would be a little difficult...
    But anways, is it possible? I know alot of people have gone with the turbo, but i think i'd rather it be a SCZ34 then a Z34Turbo. I was thinkin i'd want to be running at least a second faster... hopefully mid 13's so i can run with LT1's... Could even stick the supercharger near the top somewhere, between the heads maybe, and run that one plenum they have for the fiero's. Im hoping for around... 300-400hp possible? I know the stock internals are good for about 7psi, 11 if you want to be risky, or at least thats what i've gathered from older posts.
    This is more a brainstorming session then a straight-up question, im sure this has been brought up before, but i want new fresh ideas and input, plus im too lazy to search :P .
    2001 Mustang GT
    1991 5spd Lumina Z34 - Dead
    1947 4spd International - Dead... Reincarnation pending.. getting close now .
  • Dave
    • Nov 2003
    • 222
    I was thinking about putting a supercharger in that location actually, and piping it thru a front mount intercooler, then finding a way to plumb it up to the Throtle Body - I don't think it'd be THAT dificult.... but certinally a challenge. Especially for the intake on the supercharger.
    --Dave
    Dave ... Dave.45 ... DaveFromColorado ... it\'s all me.
    • Anonymous
      The intkae on the supercharger wouldn't be dificult at all, just stick a cone on the supercharger. There is enough room for a small filter right below the passenger side fan.
      As far as piping, it won't be that hard at all believe it or not. You will have to cut a little sheetmetal, but no biggy. Just run it behind the headlight kinda to the drivers side of the radiator, we already have a small hole for the factory airbox there, and just cut that a bit bigger.
      The hardest part will be getting it bolted down and in line with the factory serpentine system that way you aren't wearing out belts every day. In a Fiero, you don't have power steering. It would be really easy to just set a Whipple roots blower on top of our LIM, and running the pulley right to where the power steering pump went.
      • JJ77
        • Oct 2004
        • 112
        I wish I could do that but my Z is a daily driver and I live in southeast texas. I was actually thinking about making that hole bigger by the radiator and put the air filter behind the headlight in the drivers side
        1991 Lumina Z34 - http://members.sounddomain.com/lcmbear77
        1979 El camino (Faster of the two)
        FFP Stuff (chip, D Bone, UD pulley)
        Custom STB,WAI with K&N, Full Catback with Dual Magnaflows and Rative tips, 3k stall and 3.73 gearing coming soon
        • goatman
          • Jun 2004
          • 151
          Just curious, what type of supercharger would you put in the AC location? I know it that it would have to be centrifugal, but what kind? Would a Vortec fit down there?
          1993 Lumina Z34 - Broke Yet Again
          What the flip Uncle Rico!?!
          • PlatinumZ34
            • 232
            I was looking at paxton, but vortec would be my most likely choice... its actually a fairly big space down there, im pretty sure a vortec would fit. I definately think this will be one of my projects this spring :P.
            And just for shits and giggles i ran a paxton novi 2000 blower trhough desktop dyno on the 3.4, and it was looking at 210 torque at 1200rpm... and then 398hp and 403ft.lbs at 5500, and 405hp at 7500.
            Those numbers are about as accurate as me firing a sawed off .22 into water, aiming for a sign 10 feet below... ... but i thought i'd share just for fun.
            2001 Mustang GT
            • goatman
              • Jun 2004
              • 151
              I'll have to try and find one of those. It'll be best if I do it now, since my engine and tranny are both out, then I could see what kind mods are required to make it fit and work right.
              • Anonymous
                I think we can all agree that the 3.4 will eat up boost like crazy. I wouldn't be surprised that a well designed intercooled S/C system, with headers and exhaust to go with it, would make over 400hp.
                • goatman
                  • Jun 2004
                  • 151
                  There wouldn't have to be any computer mods other than a chip uprade, right? The MAP should be able to handle everything else, I'm guessing.
                    • 13534
                    You would need a 2 bar map sensor and a chip programmed for 2 bar. The stock chip setup doesn't allow for this to be easily done. MAF setups don't need as much work to control the boost.
                    • goatman
                      • Jun 2004
                      • 151
                      Gotcha
                      • ez112
                        • 258
                        I like your thoughts, there Platinum. Paxton kicks ass.
                        And I wouldn't doubt a well designed charger kit from them would bring in well over 100+ HP at the crank.
                        And for room. Come on! If you can squeeze THIS in a vette
                        then a 3.4 compartment is like a trunk. Only problem is, Paxton would want a boatload of money for the kit, and that's even if they'll even remotely consider making it.
                        1999 SVT Lightning
                        1996 Monte Z34 R.I.P.
                        Next BEATER: a C5
                        http://www.fquick.com/ez112
