3.4L DOHC performance rebuild
  • skeeterone2
    • Jan 2004
    • 115
    #46
    yo that is the exat place i got them... when you are doing your rear lights the owners maual tells you that all the lights in the back are the same... well they are not. take a side out and lookat the lights you need to get because i purchaced 4 extra bulbs for mine and sill havent got replacement ones for the center two bulbs on each side becase those are the bulbs that just stay on and they are small ones as oppose to the big turn signal or brake lights. but i just put em in my 98 blazer and i was happy... okay one more thing about getting led lights you need to get an electronic flasher for them if you want the flasher to blink normally its about a buck and it directly replaces you old flasher... what happens is that the led bulbs dont suck as much electric therefore the stock flasher thinks a bulb is out and flashes like 100 times per sec... but hey if you like that its kool im just saying to maintain your original flash rate you need to buy an electronic flasher... and now with my leds in when im parked and i hit the brake i dont hear the fuel pump fluctuate or my front lights get a tiny dimmer. with the electronic flasher you will have to let it break in... it flashes slow at first but it gets to normal rate in a week of usage.
    91\' Mazda miata.
    92\' Lumina (sold)
    • Lyle's GTP
      • Jan 2004
      • 1345
      #47
      Cool, thanks. I definatily would have been really pissed about both of those things.
      Lyle
