throttle plate
  • PaulGTP
    • Aug 2004
    • 8
    throttle plate
    Where can you get a 70 mm throttle plate, I'm assuming that is a max you can fit it in the plennum of 91-93 W-body. and what is a max bore for the plennum
    Thanks
    Paul \"Red Baron\" GTP, 91 5 Speed
    • 13533
    have to have one made somewhere as far as I know. TB and plenum are the same, so I dunno what you are asking exactly. 70mm should fit, but I was planning on using 69mm TBs before I gave up on the stock plenum design. The area behind the TB is probably closer to 50mm diameter, stretched out. Not much you can do with that design.
    • d.o.h.c
      • Jun 2004
      • 981
      i have 4 plates left. i am having my plenum horizontal milled to the exact size of the plate
      http://60degreev6.com/index.php?name...808&highlight=
