Ok car really needs an intake......what is a good intake option.....i have thought of jsut getting a drop in kn or airhog.....that gonna make a difference or what?......or what do you recomend?
Intake options......
-2000 GTP - 332/426
-94 GTP - Stock, But needs new:
Door, Steeringwheel, fender, windshield and window for new door, and power steering line.Tags: None
Well, it can't hurt. OK here's the best way to get awesome gains from a drop-in K&N. First you take your old air filter out and paint it with one or two coats of oil based paint nice and thick. Make sure it isn't on the engine side of the filter (bottom). Then, let it dry and reinstall.
Next thing, drive your car for a day or two with your modified factory filter. It may not run but all the better.
Better, why? You ask. Because when you drop that K&N in there, you will have 210HP more that stock. Now those are good numbers, better than a supercharger. Oh, yeah!!!!
Just kidding. But I think you get the point. You will NEVER get more than a few HP from an intake. K&N are a good investment cause they are reusable and have good filteration. You probably won't notice any power gains to speak of.
Lyle
True Cold Air, or Ram Air is the best way.
I have mine for sale, grabs air from the fenderwell. 3" powdercoated mandrel bent aluminum. See my thread, located here:
http://www.60degreev6.com/index.php?...ewtopic&t=4229
Smartass
There are noticeable power gain. arround 5-8 HP, i don't know for sure, i never dynno that. And you guys can be more specific, are you talking K&N Filter in factory box or Cone K&N Filter with NO factory Box, That is a big diffrence
Originally posted by Lyle's GTPWell, it can't hurt. OK here's the best way to get awesome gains from a drop-in K&N. First you take your old air filter out and paint it with one or two coats of oil based paint nice and thick. Make sure it isn't on the engine side of the filter (bottom). Then, let it dry and reinstall.
LylePaul \"Red Baron\" GTP, 91 5 Speed
damn you guys do you realy nee dto razz the guy like that about the air filter lol
but yeah aaron is right about the cai route a pipe from the tb to out side the engine bay and put a cone filter on that bitch you will notice a difference even if just a small oneI Like V660s
Does Chevy make beer
~Jayme~
There is a negligible difference on hp if any at all between a short ram intake and CAI. This has been tested in the past, if you search I am sure you'll be able to track down articles relating to it. From things that I have read in the past (wish I could remember where), is that a larger power gain was generated by extracting the hot air underneath the hood than running a ram air setup. As far as the K&N itself. about the only benefit is that it's reusuable. This is in part because it is a panel filter, and it really isn't going to increase airflow capacity as much as say a cone filter will. In my opinion just get a short ram, you have less hassle installing that versuses installing the CAI.
anyone have a parts list of what i would need?-2000 GTP - 332/426
if you throw the batt in the trunk
some 4G or thicker wire Ide assume
a cone filter
PVC pipe.
Some ring clamps and rubber couplers and the such
Ide run some cheap dryer hose from the TB to wherever you want the cone to rest, then tape up the hose so its stiff, then go buy the PVC pieces that match the rout best.
Just like your headers eh aaron. Function before beauty, thats the way I look at it.Ben
