Alternator Cutoff
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Alternator Cutoff
    Anyone know how much HP an alternator pulls? And would it be worthwhile to have a cutoff switch and run on battery for the track?
    • 13534
    well, compared to the water pump and power steering...nothing. I wouldn't do that at all, as the loss of voltage will probably hurt your times more than the alt draw would. Injectors and coil packs don't really care for 12 volts.
    • RednBlack
      Wood Hippie
      • Mar 2004
      • 2795
      Just wondered. Old school really differs. Back when we had 3 belts, water pump was the only one left on.
        • 13534
        You didnt have fuel injection or tons of sensors and electrical devices in the car either:P
        • Lyle's GTP
          • Jan 2004
          • 1345
          Well, 120 Amps x 14.5 Volts = 1740 Watts (@ peak efficiency) 1 HP = 746 Watts
          1740 Watts/ 746 Watts = 2.33 HP
          Now you have to consider efficiency losses, and static mechanical losses. A rough guesstimate would point to about 3.5 - 4 HP lost at peak alternator output. I'm not sure about the efficiency of these things or static load. So maybe someone else could elaborate more.
          Lyle
            • 13534
            stock alt is 105 amps, and its 14.4 volts optimal with the car running.
            • Gemmer
              • 240
              I wonder about the friction on the pullys bearings. How many RPMs does the pully turn per crank rotation?
              maybe a larger pully would be in order?
              • Juglenaut
                • 1130
                Lyle
                That is just HP equivalent to Watts produced, it has nothing or little to do with lag on the belt and other systems.
                You would have to figure the dampener pully to alt pully ratio and find the drag at the dampener. since the dampener is larger and the alt pully is smaller the effect of the alt would be decreased proportionally.
                Since the unregulated, unrecitifed Voltage Peak to peak is quite abit so the load has to load down the regulator before it starts lagging the winding armuture.
                I am back
                Mechanical/Service Technican
                • firechiken
                  • Feb 2004
                  • 557
                  Do you guys have all this in your heads? When ever I need to figure something like this out, I have to consult numerous books and such. Guess I should have laid off the green stuff when I was younger!
                  • Lyle's GTP
                    • Jan 2004
                    • 1345
                    Yep, up here in the old melon.
                    Hey Jugs , what you said is what I meant by static load. The load of the friction of the pulley system, bearings, etc. Thanks for elaborating.
                    Lyle
                    • TheProfessor
                      • 869
                      someone said recently in another thread that you can use a 3800 alternator pully to underdrive a 660 alternator i wonder if thats so
                      I Like V660s
                      Does Chevy make beer
                      ~Jayme~
                      • Lyle's GTP
                        • Jan 2004
                        • 1345
                        I personaly feel that under driving an alternator is a bad idea. In fact under-driving any of the accesories is a bad idea. (in my opinion) When I changed my alternator to high output it changed my output curve signifigantly. I get shit for voltage/current at stock idle. I actually had to "overdrive" my alternator with a smaller pulley.
                        My lights dim all the time at idle, the power windows suck, the turn signal slows down, etc. I have actually heard that it fucks withe the things you don't know about. For example all your relays, ignition coils, doorlock selonoids, power window motors. All that shit suffers prematur failure when used at a low voltage. Not too mention you rack and pinion system fucks up when you don't have correct hydraulic pressure. As far as the water pump goes, I would imagine that you car would try to run hotter.
                        Something to consider. If it were for race purposes only, go for it, short term won't hurt anything.
                        Lyle
                        • butchville
                          • Jul 2004
                          • 41
                          or run a 16 volt battery an alternatoran cut the alter ,off to run 4hp is alot in a close race
