Turbo DOHC, Im looking for some previous intalls
  • DreX
    • Nov 2003
    • 74
    Hi, I cant remember who had his 3.4DOHC boosted.
    I need to know the specs of the turbo. Also recomendations.
    Thanx
    DreX
  • bmlawson
    • Jul 2004
    • 141
    i think it was Aaron. He could probubly help.
      • 13531
      no, it definetly wasn't aaron, and he probably couldn't help you.
      Brian used to have his boosted but he is selling his car and took the turbo stuff off (or was planning on it). Timg also has a turbo on his monte carlo. Do a search and I am sure you will find the turbo specs you want, as there was nice discussion on DOHC turbo specs already.
      • Anonymous
        They had a pretty good discussion over at W-body.com.
        RedZMonte also is in the process of boosting his 95 MCZ34. Last I heard they had the turbo, and were waiting on some other pieces.
        • Galen
          • Oct 2004
          • 27
          Since I already signed in on here, take a look at the HX35W that comes on a standard Cummins Turbo Diesel. It will flow more air than you will likely use (500+rwhp) and the 12mm exhaust housing should not effect off boost performance greatly. Best of all, they are "cheap" as far as turbos go, and last forever. I am using the little brother (HY35W) on my 2.3 Ford in the near future.
          Galen
          apparently I don\'t learn to quickly.
          • Lyle's GTP
            • Jan 2004
            • 1345
            I think Brian's turbo, (if I remember correctly) didn't work as well as he had wished. I think he said that he used the wrong turbo or the trim was wrong or something. But he had pretty much figured out what he did wrong. That info should be around here. He was very consise with his info too.
            Lyle
            • Anonymous
              Lyle
              He said that it was definately too small.
              • brian89gp
                • 554
                I said it was too small for a 5spd and for the powerband/power potential I was wanting. With an auto and up to around 6-8psi it was quite pleasant, but anything more it was on the small side.
                Recommendations would depend on your power goals, the powerband you want, and to some effect the weight of the car its going in.
                • heza
                  • Apr 2004
                  • 96
                  i have TimG vids of his turbo Z34 if anyone wants them. he said i could give them to anyone if i wanted too...
                  • PlatinumZ34
                    • 232
                    i'd definately want those
                    2001 Mustang GT
                    1991 5spd Lumina Z34 - Dead
                    1947 4spd International - Dead... Reincarnation pending.. getting close now .
                    • heza
                      • Apr 2004
                      • 96
                      PM me with an email that can hold 5+ meg files or a messenger service to send through that.
                      • mfewtrail
                        ~600hp worth of 3.1's
                        • 170
                        I want to see the vids. mfewtrail@alltel.net
                        Matt F.
                        TGP 1/4 mile times
                        http://photobucket.com/albums/y33/mfewtrail/
                        1990 TGP Coupe VIN Database
                        • DreX
                          • Nov 2003
                          • 74
                          Brian, do you have the compressor map of the ct26? Any recomendations?
                          Heza, can you send me the vids. amartinez12@tampabay.rr.com
                          Thanx
                          DreX
                          • heza
                            • Apr 2004
                            • 96
                            sorry everyone...cant get my damn email to work with me. so PM me with messenger info and we'll go from there
                            • brian89gp
                              • 554
                              Afraid I don't. I've been told is similar to a mid sized T3 stock. The T04E 60 trim turbo is pretty decent and quite affordable. .6 or .7 on the exhaust side depending on your goals.
