dual to single exhaust
  • lookatitgo156
    • Nov 2003
    • 3
    i was wondering if changing the exhaust from a fake dual to a single outlet would affect anything. and if not, whats a few good choices of mufflers. thanks
    1991 LUMINA Z34 w/ 3.4 litter fi engine - i love the thing
  • Anonymous
    It shouldn't affect performance as long as you have good pipe. It will probably change the sound (for the worse), but I was reading in a post somewhere about a Flowmaster(?) muffler that was designed for that, and is suppose to sound really good.
    If I were to make single exhaust, I'd have the pipe exit out the side before the rear tire with a rectangle tip.. that would look cool
      • 13531
      It changes the exhaust note. I am using a single 2.5 mandrel bent exhaust with a flowmaster 40 series. I love the sound, except when its cold it gets a bit raspy at a small RPM range.
      • Rhedalert
        Dr. Feelgood
        • 1574
        Is that on the Cutlass?? I remember the GP still having the duals. Didnt that car have a 2.5" exhaust too?
        Brian
        3400 SFI V6, 4T60e
        • Cliff8928
          • 532
          Well, if you wanted to lighten up the car a bit, and not leave that one cutout open on the other side of the car where the other muffler would have been, you could alwyas get a muffler designed for a F-Body and just route a pipe over to the other side to save some weight instead of having another muffler over there..
          And there sure isn't any shortage of F-Body aftermarket mufflers out there...
          Cliff Scott
          89 BerettaGT
          89 Volvo740
          Cliff Scott
          89 BerettaGT
          04 AleroGX
          • Anonymous
            Its easy enough to cover any cutout spots with fibreglass, and it will hold strong too. Just as long as you want to do some painting as well.
            • lookatitgo156
              • Nov 2003
              • 3
              ok i am planning on removing everything from the cat back, installing high flow cat, 2.5 inch tubing into a magnaflow or flowmaster, what difference other than sound would this have over the stock exhaust?
                • 13531
                performance and less weight.
                Its on the cutty, cause I took it off the GP I got rid of the Y split too.
                  Just needs a resonator now to get rid of that God awfull raspy sound from 2.5k to 3.5k now, lol. Man I hate that sound from our engines, lol.
                    • 13531
                    tuning kinda fixed that, its only raspy to 2-2.5k when its warming up. Its much mellower than it used to be when it warms up.
