96-97 Cam Retard
  • BMFH
    • Jul 2004
    • 42
    96-97 Cam Retard
    Hello
    Has anyone done the exhaust retard on the 96 or 97's yet, If so how does it work with an Automatic Trans?
    Thanks in advance
    John
  • pepsi_coke
    • 288
    Werent all the 96/97s automatic anyways?
    New member of 200,000 mile club as of May 16, 2005
    • BMFH
      • Jul 2004
      • 42
      Hello
      Don't know about that, but mine is an automatic, I have seen some post's that talk about standard transmissions and automatics, thats why I asked about the automatic.
      John
        • 13505
        They are all automatics. You would have to experiment with the cam timing, but do not run 13 degrees retarded on it as the stock exhaust cam is already 3 or 4 degrees retarded compared to 91-95 I believe. Intake is advanced in comparison as well. Being an automatic doesn't mean that changing the cam timing won't be beneficial, though I would consider more advance on the intake and a little more retard on the exhaust. Ill know what that cam timing does on the 91-95 in the next few days.
        • your_I.D.
          • Mar 2005
          • 337
          Tried out my new cam timing tool today.
          A major improvement on the bottom end!!
          Assuming there is a factory +4 int & -4 exh. already set from factory.
          My settings by the new cam tool:
          intake +2 (which is +4 crank degrees) then add in the factory +4 = +8 total
          exhaust -2 (which is -4 crank degrees) then add in the factory -4 = -8 total
          So: +8 intake
          -8 exhaust
          Correct if im wrong.
          1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
          • NOSTZ34
            • Feb 2009
            • 9
            So: +8 intake
            -8 exhaust
            So is this the best setup for 96-97 3.4 DOHC automatics? Thanks
            • GTP091
              • Jun 2005
              • 232
              this thread is from 2005... you probably wont get a response.
                Well since 60v6 isn't a flame pit like most forums, you never know
