ignition
  • 95whiteprix
    • May 2005
    • 40
    ignition
    I just recently purchased a jet performance module, a magnaflow converter, flowmaster mufflers and I took the stock airbox out and put a cone filter on the intake. Now i'm looking for plugs and wires. The thing is i found nology wires for the 93-95 camaros but not for my pontiac. I am wondering if all the 3.4's are the same or if the rear drive camaro 3.4's had different ignition on them.
    The only thing better than GM is a GM with a 60V6 under the hood.
    • 9191
    RE: ignition
    The DOHCs require a different connection on the plug than the pushrods, and the lengths would be quite different. Do a search for Magnecor wires for a good set of wires for the DOHCs.
    • Dave96z34
      • Apr 2005
      • 624
      Magnecor is the best dohc wires on the market. And if you want a good ignition system MSD DIS-4 is the best for the motor. Here is a list of all the parts you need.
      Magnecor wire set pn65202 (8.5mm red for best results)
      MSD DIS-4 Ignition pn62152
      MSD Coil Interface pn8870 (3 needed)
      MSD Blaster Gm Dual Coil Pack pn8224 (3 needed)
      edit
      AutoLite Copper Core Spark Plugs (no platinum or hype spark plugs they get to hot)
      For the wires
        • 13531
        The DIS-4 just gives better gas milage, no performance increase at all. Had one on my 3.1 and tested it at the track. Magnecor are the wires to get, nology are a joke. The jet module is a joke too, you should just get rid of it now cause its not going to do anything for you.
        • Dave96z34
          • Apr 2005
          • 624
          My setup is track proven. It took off .22 seconds in the 1/4. I tested it with the bypass module at new england dragway like 3 weeks ago. I agree with you on the jet modules they are a joke.
          • pwmin
            • Aug 2004
            • 394
            ixnay on the autolites. i dont care if you have dyno or tack proven results to say they are better than delco's, i still wont believe it. id just get the magnecore wires and forget about all that other stuff. imo, its not worth it. the 8mm mc wires cost about the same as delco's, a little more.
            91 GTP HM-284 GONE :(
            98 Spawn of Satan (L67 Regal)
            87 V10 SM-465/Mild 350
            06 Cobalt SS/SC GONE :(
              • 13531
              Thats how I ran mine with the 3.1, bypass plug, plugged in. Repeat back and forth with nothing gained. I guess we need a dyno to sort this one out.
              • Dave96z34
                • Apr 2005
                • 624
                There is one about 45min away from me but no one is ever at the phone so I dont no there time's. The next is 15min more of a trip and they are very active. I will go as soon as get the new rims for my M/T . One of the rims came with a bad defect.
                  • 13531
                  Cool, that will be interesting to see some dyno results. Maybe the 3.1 doesn't need it like the DOHC does, i dunno.
