Lower intake porting
  • Chilicat
    • Feb 2005
    • 9
    Im gasket matching a 94 z34 plenum and lower intake, should I port and polish the
    whole lower intake???
    Any advice will be appreciated , thanks
    Chilicat
    • 13533
    RE: Lower intake porting
    go for it. The lower intake varies, I have seen decent ones and some that need a ton of work. The side walls could use a good clean up.
    • Chilicat
      • Feb 2005
      • 9
      Thanks!!
      What about the plenum ?, (extrude honing out of budget) read something about acid
      porting, worth it?
      • your_I.D.
        • Mar 2005
        • 337
        Ben have you ever tried using flexable ball hones? To do upper intake plenum. Thinking of the 97 type with the long runners.
        1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
