71 mm throttle body
  • d.o.h.c
    • Jun 2004
    • 981
    71 mm throttle body
    well here it is i got the plenum bored out with a horizontal mill and had the plates cnc machined.
  • d.o.h.c
    • Jun 2004
    • 981
    more
    • d.o.h.c
      • Jun 2004
      • 981
      more
      • pepsi_coke
        • 288
        Awesome! Did you test run it, any noticeable difference?
        Did ya feel as if it was worth the $$ ?
        -Jay
        New member of 200,000 mile club as of May 16, 2005
        • d.o.h.c
          • Jun 2004
          • 981
          i did it for cheap. i know people in the business. i have not tested it yet it has been sitting around for a while. i am going to test it soon. i was thinking about selling it because i want a 96 throttle body manifold
            • 13531
            Id like to see some dyno results with the larger TB. I know RSM charges a ton for theirs and I personally don't see it making a huge difference with the rest of the plenum setup. Thats opinion, not fact so I would love to see some real results on doing this.
            • d.o.h.c
              • Jun 2004
              • 981
              well it in and the car is much slower i punched it at a dead stop and it shifts gears at 4,000 have not tried at 30mph though. manybe because the tps sensor is not hooked up. well it sure is louder.
                • 13531
                Yeha, the TPS sensor has to be hooked up.
                • d.o.h.c
                  • Jun 2004
                  • 981
                  yeah becuase the spedo does not even work . do you think that affects anything
                    • 13531
                    No, the TPS is used for shift points. Dunno what the deal is with the speedo though, nothing intake related.
                    • d.o.h.c
                      • Jun 2004
                      • 981
                      well i took a look at theshaft and it looks to be off. so at closed throttle i am getting .000 voltes. were i should be getting .50. so i have to bend the shaft back and make it fit that way. it says that the tps has a lot to do with the fuel to so that is why i think my car is so slow right now
                      • d.o.h.c
                        • Jun 2004
                        • 981
                        well i bought a new tps sen sensor and i still get nothing. but when i push on the pedal and get the voltage to.50 the ses light goes off. so i look at the shafts of the new throttle body and my stocker and there the same but the tps sensor does not read the right voltage. and my shift point are crazy like shifting at 3,000 floored so i need some seriously help
                        • d.o.h.c
                          • Jun 2004
                          • 981
                          and my spedo does not work still think it could be the tps because it stoped working after i switched the throttle bodies
                          • d.o.h.c
                            • Jun 2004
                            • 981
                            holy cow i had the spring on backwards so i fixed it and got that thing is awsome and it is so loud. wow it halls now i low it is sounds like a turbo that deep
                            • d.o.h.c
                              • Jun 2004
                              • 981
