upper intake and TB work
  • Jculler1610
    • Jan 2005
    • 36
    Has any one looked at this site, http://www.domesticperformance.com/d...hp?cPath=3_346, they will port the upper intake, and bore out the TB. I also saw that they will do a lower one for a 95 monte wiht a dohc. do the 91-93 and the later years have the same lower intake manifold ? And is so They can do both at a decent price. Thoughts would be great.
    Joel
  • z34phoenix
    • Jun 2005
    • 469
    RE: upper intake and TB work
    that one is for the 3400 not the 3.4 dohc different engines here is a link to a site that will do what you want. http://milzymotorsports.com/
    or if you want go to my WWW i did my intakes and i took pics and made a writeup for it on pg 6
      • 13534
      The 95 DOHC intake does not look like what is in that photo. It depends on what you want to do with the motor. A custom intake would probably be best, or extrude hone. Really depends on your goal with the engine though.
      • Jculler1610
        • Jan 2005
        • 36
        when you go to that site, I went to chevy, then lumina then 3.4, I thought dohc 3.4 was the only 3.4 in lumina's? And as for the first reply do you still make them and how much. Does that include the TB. I think this would be a great thing to have on in the store on this site. oh I know this is kinda of out of this sections topic but...i read a while back there is a way to drop the rear end leaving the monoleaf by moving somethings I think rsm had a way. does ne one know wat it is.
          • 13534
          I do porting work as well but haven't added everything to the store yet.
          • Jculler1610
            • Jan 2005
            • 36
            Will you do a set of upper and lower intake manifolds for me wiht a bored out Tb, and if so how much
              • 13534
              I cannot do the bored out TB without outsourcing it to someone that can do it. Since the TB is attached, its not as easy to line it up, or I would have this done already.
