FFP's Dogbone Mount?
  • Kyles93Z34
    • Dec 2004
    • 347
    I was wondering if the dogbone from Fast forward performance actually gets more power to the ground. Would there actually be a noticable differance in the performance of my 93 Z. Thanks.
    Kyle
    1992 Lumina Z34
    5 Speed
    Autozone civic intake
    Ultra White lights
    FFP Dogbone mount
    125k miles
    2.5 inch Magnaflow catback from Magnaflow cat
    60degreeV6.com Custom Chip
  • DrRodey
    • Nov 2004
    • 76
    In theory... yes. What it does is stiffen the joint between the engine and frame so the extra rotational torque is retained instead of twisting the dogbone. Creates a rougher feel to the idle, more engine vibraiton felt in the car. As for actually improving hp output?? I'm skeptical but I still have one on my GP.
    92 GP GTP 3.4DOHC 5spd
    88 Fiero Formula CONVERTIBLE 3.4DOHC 5spd
    84 Fiero T-Top 3.4DOHC 5spd
    There seems to be a pattern there.
      • 13534
      Its not going to put more power to the ground once you are moving. Its the instant throttle snap that you get more to the ground. After the engine is done torquing on a rubber setup, its still putting the same through the trans and axles.
      • RednBlack
        Wood Hippie
        • Mar 2004
        • 2795
        Poly Mounts do not add HP to the engine. They do however add HP to the wheels at take off as Ben said, and in each gear change. And although I like that, my favorite added attraction of a Poly-Bone, is the transfer of sound throughout the Uni-Body. Frame cars don't get this. It does not affect your idle, you just feel and hear it more. Body Harmonics. I'd like all Poly mounts if I could get them.
        Working on that...
        • z34phoenix
          • Jun 2005
          • 469
          well the mount will not change or add HP
          what everyone is thinking about it Tq it is the torque gained from limiting the engine movement not HP.
          i have seen Quotes of 5-10 lbs gained at launch, but am sceptical about that. after i got mine, i noticed that the car seemed more resposive to sudden throtle changes.
          • Kyles93Z34
            • Dec 2004
            • 347
            I got it in the mail tonight and i love it. I went outside at 8 and put it on. I immediately noticed the differance in sound. It is alot louder inside the car but it actually smoothed out the idle. My car used to shake alot during idle. I went and drove around and it wanted to spin the tires alot more than usual. I wonder if this will improve my 60ft times? And if so, how much.
            Kyle
            1992 Lumina Z34
            5 Speed
            Ultra White lights
            FFP Dogbone mount
            125k miles
            • OldSkoolGP
              That guy over there
              • 930
              I find it easier to break the tires loose with mine. I'll be ordering another one for my new GP very soon, the stocker is completely shot.
