Ahite! What now?
  • RednBlack
    Wood Hippie
    • Mar 2004
    • 2795
    Ahite! What now?
    I feel like a dog that caught the car. What do I do with it? Just bought these... http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
    I know first thing is to get them home and tear them down.... Then what? Note that they are both 94s. I have my doubts about the bent valve.
  • LeftVentricle
    Right aorta
    • Oct 2005
    • 506
    Well, like the seller said, you can cannibalize one engine to make the other real good. If the one has a bent valve, you can just swap in a head from the other one or what-have-you, and it's good as new! If I'd had the ability to get to/from Kentucky I would have jumped this immediately. My 6000 is sad right now, with the Iron Duke in it. This would have been a perfect swap.
    • your_I.D.
      • Mar 2005
      • 337
      Re: Ahite! What now?
      Ya, no doubt. 94 was a non interferance motor.
      1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
        • 13532
        Clean them up, tear them down, label the parts, and see what you got I wanted to get them as well but no easy way to get them. Ive got a 3100 and a 3400 now though and a 95 DOHC so I got enough motors for the moment.
        If the one head has a bent valve, I wanna see a pic of it and the piston.
        • RednBlack
          Wood Hippie
          • Mar 2004
          • 2795
          You got it. And Ben, how much have I spent, just trying to find a set of heads? This will be fun! 2 complete LQ1s for the price of 2 cheap tires. And I still have 1 in my car.
          (Woody)
            • 13532
            No doubt, should have just waited it out for this one (two).
            Time to get some engine stands
            • RebelGT
              • 642
              26+6=1
              • gboogie99
                they still can't catch me
                • Nov 2005
                • 348
                damn good deal
                • RednBlack
                  Wood Hippie
                  • Mar 2004
                  • 2795
                  Well, the "Twins" are home and nestled in their garage. I'm a little confused about the twins part however. One has a manual flywheel mounted to it, so obviously it can't be a 94. Can I tell by casting numbers? Or what are some other differences? They both look identical except for the plastic injector covers. Both have the one piece TB/plenum.
                  BTW, I asked John to join our little club. (He has 2 94 Cutty Ragtops) ((Homer Drool))
                  I will have them both disassembled, labled, and catagorized by the end of the week. Then the fun begins.....
                  BTW rebel, the thought has crossed my mind.
                  • Husky
                    It's like... ya know?
                    • Aug 2005
                    • 200
                    1994+ says 3.4 DOHC
                    1991-1993 says Twin Dual Cam V6.
                    I have one of each to swap out when I'm feelin froggy.
                    1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
                    1995 BMW 540i, Alpineweiss-III, 6-Speed
                    1995 BMW 540i, Schwarz-II, Automatic
                    2004 Honda 919, Light Silver Metallic, 6-Speed
                    • Husky
                      • Aug 2005
                      • 200
                      Also, check the oil presure sending units. 1994+ will be much smaller because it was a light instead of a guage.
                      • RednBlack
                        Wood Hippie
                        • Mar 2004
                        • 2795
                        I understand the 91-93 part, but my 94 has a gauge. So I obviously have a 94 and a 91-93. I thought so. The 91-93 also has Emission tubes on the exhaust manifolds. Is that right?
                        Any difference in the block itself? And what other differences can I expect?
                        • Fierobsessed
                          • Mar 2004
                          • 219
                          Emmissions tubes? think that means its a 5 speed motor IIRC.
                          • RednBlack
                            Wood Hippie
                            • Mar 2004
                            • 2795
                            Well, just as I thought, no valves bent. Engine I'm using looks really good inside. Sorry no pics yet, my internet is down, and I'm using companies PC.
                            Neat thing about LQ1, shreds the belt, all flats go striaght up.
