Most power from the 3.4 DOHC?
  • donk_316
    • Mar 2004
    • 427
    #61
    for 400 bucks i might throw my 96 cams at them...why the hell not? it would be over the winter project.
    1984 Indy Fiero 3.4L
    13.7 sec @ 98 mph
    *ALL THROTTLE AND NO BOTTLE*
    • series8217
      • Dec 2004
      • 387
      #62
      To keep things down to earth, remember that you'll also need lash caps for the valve stems (not a big deal), and possibly different valve springs (probably a big deal).
        • 13531
        #63
        4.6 SOHC springs, and shim if you need stiffer. I gotta price lash caps but I believe crower can tell you what thickness you will need (i think they may have been checking into it for someone else).
        • series8217
          • Dec 2004
          • 387
          #64
          What are the specs on the rustang springs? What max cam specs can they be used with?
          • ryan.hess
            • 526
            #65
            What are lash caps for?
            Is that because they cut from the base circle, so you need them to get back to "zero lash" on it?
            Okay now, that's enough of that.
            • Fierobsessed
              • Mar 2004
              • 219
              #66
              yes
              • Jakemetz63
                • Sep 2005
                • 24
                #67
                head over to w-body.com/forum
                A guy in Toledo is selling a crap load of new LQ1s for pretty cheap.
                edit* http://www.w-body.com/forum/index.ph...c,40455.0.html
                • FieroWannaBe
                  • Mar 2006
                  • 78
                  #68
                  dragging this old thread up, to let everyone know I bought a LQ1 against all advise, a 96 with 89k miles. 400$
                  Something cool coming soon...
                  96 LQ1!
                  • FieroWannaBe
                    • Mar 2006
                    • 78
                    #69
                    http://www.fiero.nl/forum/Forum1/HTML/059855.html
                    so far Mat Hawkins looks like he is pulling the most power I've seen, 387whp; 358ft-lb on 13.5 lbs of boost
                    96 LQ1!
