Stage 3 Clutch kit
  • wiseway
    • Feb 2006
    • 28
    Stage 3 Clutch kit
    Does anyone know where to get a stage 3 clutch kit for a lumina z34 that has the 3.4 DOHC. thank you.
  • richlo65
    • Jan 2006
    • 8
    im pretty sure spec would definatly have one (www.specclutch.com), or else other big companys like clutchmaster, ets.
    86 Fiero 3.4 DOHC, 13.9 @ 101 mph as it is on the street.
    87 Fiero GT with a 400hp SBC before nitrous, 500-550hp after nitrous.
    • RebelGT
      • 642
      lol @ "stage 3"
      26+6=1
      • Mach10
        • Jan 2006
        • 232
        As a former model rocketeer... Whenever someone says "stage <blah>" I crack up...
        In my old hobby, Any stage over 1 meant that something had to explode first...
        3-stage clutch... I've had one single-stage clutch before... Having a friction plate shatter at 5500rpm left quite a mess
        • TurboGt
          • Oct 2005
          • 154
          This is the one I am looking at buying
          Mega Squirted Fiero
          How I did it here
          • dohcfiend
            King Chalupa
            • Jan 2004
            • 2351
            may want to think twice about that. i hear peeps running 282's are having alot of problems with spec's products. these may occur in a 284 also.
            there is a place called clutchnet that makes stage 3 clutches and pressure plates for the 284. the contruction on these parts is very impressive. they look to be very well built.
            don't have a link but u should google it and and check them out.
            • mr_merkur
              • Feb 2006
              • 16
              So one of the local parts houses ssays the P/N is the same from a 3.1 lumina as a 3.4 if this is true, why does Spec sell the 3.4TDC clutch stage 3 for almost tripple the price of a stage 3 from a 3.1?
              87 merkur v8 *fast wont come close*
              67 c-10 slammed and quick
              01 sc2 beater with a heater
              couple crotch rockets and other toys
              • Mach10
                • Jan 2006
                • 232
                Hmm...
                I know the 284 trans takes a larger clutch setup than the 3.1. And the TO bearings are different. Didn't the 28/3100s all use a 282 rather than the larter 284?
                With the Fiero (which is the clutch I'm using) all the clutches are the same, it's the TO bearings that differ.
                • mr_merkur
                  • Feb 2006
                  • 16
                  I'm not sure. He may have looked up the numbers for just the transmission or just the clutch, not the actual kit. Thats good info to know though about the T/O bearing
                  • Syn
                    The Master Piece
                    • Oct 2005
                    • 599
                    spec clutches are junk, a few people are giving a shot on these clutches on ebay, yea i know ebay the guy has 99% feed back tho and worth a try us over at v6z24.com got about 6 guys in on a group purchase and hes gonna drop the price to around 150-160 from 200. its a 6 puck clutch
                    anyone interested get ahold of me by wednesday
                    they are for the 88-94 cavlaier's
                      • 13525
                      They definetly are not the same clutch. Push vs pull type.
                      • Mach10
                        • Jan 2006
                        • 232
                        The 284 uses a pull-type clutch, vs. the push-type on the 284/muncie/saginaw/Isuzu, correct?
                        • dohcfiend
                          King Chalupa
                          • Jan 2004
                          • 2351
                          damn it, beat me to it. i was getting ready to say they can't be the same. b/c only the wbody 3.4tdc's recieved the getrag 284 and as mentioned the clutches are pull on the 284 vs the push type of the 3.1 tranny(most likely a 282).
                          as far as i know the only interchangable part is the flywheel and it must be neutrally balanced not counterweighted.
                          i am telling you give clutchnet a look. they have a variety of clutches and a few different pressure plates to choose from as well. they advertise a 2x but if u ask, they can make a 3x but it will not be very streetable.
                          not only that, they can do custom stuff too.
                          Find information, resources and relevant links for clutchnet.com. This domain may be for sale.
                          • mr_merkur
                            • Feb 2006
                            • 16
                            checked out clutch net and its looking pretty good. Syn, do you have a link to that clutch and/or the group buy info?
                            • Syn
                              The Master Piece
                              • Oct 2005
                              • 599
                              really i was thinking about buying from clutchnet.com but they don't give h/p ratings or anything just stop lights lol red being the highest level of course. but around 150-175 shipped for a whole ebay kit is worth the gamble i'd say.
                              you will have to be ready by thursday or friday
                              Anyone interesting in buying one of the Stage 3 Clutches off of eBay? http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=8035022400&rd=1&sspagename=STRK%3AMEWA%3AIT this clutch can pull up to 375hp 2200lbs clamp load. this is a stage 3 with heavy duty pplate and heat treated diaph...
                              if interested contact me at thysynster@aol.com
                              because this site sucks with pm's and notifications
