reground on my stock 3.4 cams/ engine question
  • d.o.h.c
    • Jun 2004
    • 981
    i have my cams at crower right now and they need to know a little info. can you guyes help me out here is what they asked.
    * What is the O.D. if your lifter (bucket) ?
    * What is the valve stem size?
    * What is the measurment from the top of the keeper (valve lock) to the tip
    of the valave. We need this to see if we can fit a lash cap on the tip of
    your valve.
    * Just to make sure we ware on the same page, 3.4 Chevy V6 dohc. 4-cams for
    one engine. Correct?
    also i checked the clearnces on my rods to crank side clearance and some are 20 thousands. now the 94 gm manual say 7-17 and the 92 says 7-24 what should i go by and what are the difference. the engine getting the cams is a 94.
    • 13531
    91-96 are 35mm, 97 are 33mm lifters. 7mm stem. .136" from the lock to the stem tip.
    • d.o.h.c
      • Jun 2004
      • 981
      ben is the fucking man. thanks man i will e-mail him right now. sweet
        • 13531
        Let me know on the lash caps. Comp makes some as well though im not sure on the length. I think they will work. I was checking them out for my solid lifter dream. At about 40 bucks each, its gonna be a dream:P
        If you can get some stock specs from them, that would be cool. thunder racing doesnt know how to get a centerline if its not a V8 (what a freakin waste!). Im curious what specs they recommend as well.
        • tijuana_no
          • Aug 2005
          • 261
          hey,dohc, how much is crower charging for this(i didn't thing crowewr did regrins for owr engines).
          hey ,ben too bad you live to far or i would let you built your dream in my engine.but,if you ever up to it ,i 'am wiiling just come up with some #'s.
          i just love to watch the wheels turn around and around
          • d.o.h.c
            • Jun 2004
            • 981
            what specs you guyes need. also i talked to brian crower. he gave me a price of 100$ per cam *4 =400 plus i had to pay 15$ for shipping back. also had to have a special box made for the cams to go from florida to california and not get ruined. so about 500$ for the whole thing. dj at crower told me that he would try to keep something stock and go 20 thousands on something else because it is going to be a turbo car. but for a regular regrind i think he said 10,10. yeah let me know what specs you guyes need. i will e-mail him and get you the info no problem. hope they run good
            • HayesPerformance
              • 783
              1991 Rod Clearance
              Hey d.o.h.c.
              On the 1991 3.4 DOHC
              the ROD SIDE CLEARANCE IS 0.36 mm-0.64 mm (.014"-.025")
              Check with GM to be certain of the right clearance.
              Regards,
              David Hayes
              1991 Grand Prix STE
              3.4 DOHC
              1 of 792 Produced
              Extensive Mods Done
              1991 Lumina Z34
              3.4 DOHC
              Getrag 284 5spd
              1 of 30
              • d.o.h.c
                • Jun 2004
                • 981
                yeah my 92 gm manual say that but the motor i am rebuilding is a 94 and the gm shop manual say 7-17. but everything on the bottom end is the same. why they do this and do you think i ok with 19 on two rods.the rest are around 13-15
                  • 13531
                  I just need to know the centerlines. I know GM spec is 111 and 112 but I wanna make sure.
                  • d.o.h.c
                    • Jun 2004
                    • 981
                    WILL DO.
                    • your_I.D.
                      • Mar 2005
                      • 337
                      Right on!
                      1997 Z34 Monte,: testing 4 exh cam\'s, RSM STB, K&N, Eagle077 245/40/ZR18 Nitto Extreme
                      • dohcfiend
                        King Chalupa
                        • Jan 2004
                        • 2351
                        sweet......glad i clicked on this. perhaps ben will be right about 2k6 being the year of sickness.
                        • ez112
                          • 258
                          This is so badass. I can't wait to hear the final results of this.
                          Kudos to you, d.o.h.c
                          1999 SVT Lightning
                          1996 Monte Z34 R.I.P.
                          Next BEATER: a C5
                          http://www.fquick.com/ez112
                          • d.o.h.c
                            • Jun 2004
                            • 981
                            NEED HELP.
                            Ok just talked to dave crower and he is telling me that I am going to need to use some type of shim on the cams. I have no idea what he is talking about. he said that he is getting new lash caps but needs to know the clearances as far as the BUCKET goes. any body.
                            • your_I.D.
                              • Mar 2005
                              • 337
                              just deck the cam carriers the amount crower takes off the base lobe
