95 heads vs 96+ heads
  • GTP_MuNkY
    • Jan 2006
    • 113
    OK, so it looks like now I'm going to have the heads off my engine along with the intake assembly, so I'm considering going to the 96 heads if I can find a decent set. I also plan on attempting to get the Ford SOHC springs for it and the shims from the 60*v6 store, along with a good P&P job.
    Aside from the size and shape of the exhaust ports what difference is there? I tried doing a search for 96 heads but it came up with 1400 and some odd results on 30 pages.
    Also, when going to the 96 heads should I also go to the 96 upper and lower intakes? I know the upper intake has a separate peice TB, but is the lower intake really neccessary?
    If anyone could link me to a thread on possible performance advantages or differences in the heads it would be greatly apprieciated.
    Thanx
    Jamie
    1995 Pontiac Grand Prix GTP
    3.4L DOHC
    My Cardomain Page UPDATED MARCH 10, 2006
  • timg
    • Feb 2004
    • 718
    Here are some pictures.
    Tim
    325 whp 350 lb-ft
    • 95black34
      • May 2006
      • 19
      How much better is the 96+ heads?
      1995 Black Monte Carlo Z34
      soon to be rebuilt
      • donk_316
        • Mar 2004
        • 427
        alot.
        1984 Indy Fiero 3.4L
        13.7 sec @ 98 mph
        *ALL THROTTLE AND NO BOTTLE*
        • 5speedz34
          • 301
          Originally posted by donk_316
          alot.
          Has this been determined? I thought the only real improvement is in the exhaust port(flows better). Wouldn't a ported head flow as well if not better?
          • timg
            • Feb 2004
            • 718
            The combustion chamber shape is better also. It should result in better emissions, more power, and more detonation resistance.
            Tim
            325 whp 350 lb-ft
              • 13525
              Im not convinced of the 96/97 heads superiority yet.
              • 93GTP
                • 125
                Does anyone know what the difference in volume is in the combustion chambers of the 96-97 heads versus the 91-95's? I know supposedly they are smaller but does anyone know the volumes of each? Or does anyone have access to a set to cc them? I'm trying to figure out what compression ratio I would be at if I used a set of 96-97 heads with the 91-93 standard pistons. I'm thinking about swapping these heads onto the 92 Z34 engine I'm rebuilding.
                For that matter I would like to verify that I can swap to the 96-97 heads without any problems?
                  • 13525
                  91-95 are 54cc and 96-97 are 51.5cc
                  • 93GTP
                    • 125
                    Thanks Ben, once again you have the answers. So I would get a small bump in compression if I swap to the 96-97 heads, a little over 9.8:1 with the standard pistons I believe. Has anyone swapped to these heads on a pre-96 engine and kept the original cam carriers and intakes? I want to make sure they would swap onto my 92 engine without presenting any problems (does everything bolt up the same below and above the heads)? Also has anyone ever gotten flow numbers comparing the 2 designs?
