total seal ring questions
  • birdman
    • May 2005
    • 274
    i know you have to have the specs for your pistons but do they have to be YOUR pistons? or do you just need the stock piston specs??? thanks.
    92 Lumina euro 3.4 DOHC 139,XXX miles
  • birdman
    • May 2005
    • 274
    nobody knows the answer??? ben?? any input???
      • 13525
      What pistons are you using? Thats the specs they need to know. Im confused on why you clarified "your" pistons. your pistons will be the same as my pistons if we both have the same part number.
      • birdman
        • May 2005
        • 274
        well what i meant is if they need you to measure your pistons because all pistons cant be the exact same, well stock ones at least. i know if i go with the h pistons i can get the info from them.
          • 13525
          They are all stock replacement pistons unless you get custom pistons made. Therefore you just need to know what year. They should have the 3.4 DOHC piston specs already.
          • birdman
            • May 2005
            • 274
            well i forget who but they said youd need to measure your pistons and have them made to that size, thats why i asked. thanks alot though it really helped.
