Stroker crank
  • timg
    • Feb 2004
    • 718
    Stroker crank
    I know a forged stroker crank using GM parts had been mentioned before. What happened with that? Thanks.
    Tim
    325 whp 350 lb-ft
  • Fierobsessed
    • Mar 2004
    • 219
    It's an offset cut 3500 crank. You can have this procedure done at any really good competant race engine machine shop. Maximum possible offset grind would get you about .250" extra stroke or really just a hair less. Without any bore work, 3.6L Even. If you do a .060" overbore, you can achieve an effective displacment of just over 3.7L (yikes!)
    • Fiero Brick
      • Feb 2006
      • 71
      I just drooled on myself.
      3.6 (almost 3.7? Isn't .060 over in the danger zone on the 3.4?) liter LQ1? Even not taking into account that the compression ratio would (I think) be increased by stroking the engine and any boring done, desktop dyno is showing a gain of almost 15 lb*ft and 10 horsepower. That would be an awesome base for building a high-horsepower NA LQ1... or a high-horse turbo LQ1 for that matter, too.
      I never thought of offset grinding the 3500 crank... shows how much I have left to learn.
      87 Fiero GT
      2.8 liter v6
      • prophiseer
        Blaspheming Heretic
        • Jun 2006
        • 354
        Not everyone knows everything about something, but everyone knows something about everything. We're all still learning, y'know? Hell, I think most people here know more than the engineers that're designing our motors and cars
        N-body enthusiast:
        {'87 Grand Am SE - 3.0 90* v6} / {'93 Grand Am LE - 3.3 90* v6}
        {'98 Grand Am SE - 2.4 Q4} / {'99 Grand Am GT1 - 3400 60* v6}
        Current Project:
        {'90 Chevrolet C1500 Sport 350TBI}
        • tijuana_no
          • Aug 2005
          • 261
          i only know, that i don't know nothing.
          i just love to watch the wheels turn around and around
          • timg
            • Feb 2004
            • 718
            Does anybody have the part number for the forged 3500 crank? Thanks.
            Tim
            325 whp 350 lb-ft
            • prophiseer
              Blaspheming Heretic
              • Jun 2006
              • 354
              I was thinkin earlier . . . going with the 3500 offset, if you bored a 3400 block about .050-.055" over, you'd still be relatively close to that 3.7 mark, but still be within block tolerance, especially on an iron block.
              Or (unless someone has tried it), bore the block well past max allowance, and then sleeve the cylinders back down, the extra reinforcement would help.
              Oh, and BTW, does anyone know how similar the 3900 block is compared to the 34/3500's? Are the target for a short block swap, or are tere too many differences to overcome?
              N-body enthusiast:
              Current Project:
              • Dave96z34
                • Apr 2005
                • 624
                wouldn't that be like 12-1 comp. That with boost would kill a head gasket quick.
                • Dave96z34
                  • Apr 2005
                  • 624
                  • Fiero Brick
                    • Feb 2006
                    • 71
                    I didn't run the math... I'm pretty sure I would have to do more research before I even knew how to go about checking that. but with 12-1... sounds like it would be awesome for an extreme-street NA application...
                    87 Fiero GT
                    2.8 liter v6
                    • Husky
                      It's like... ya know?
                      • Aug 2005
                      • 200
                      Pft, if you're gonna bore it that much, and stroke it that much, and boost it that much, and do all that work, and you don't go with a rather extreme headgasket, you deserve the blown ones. Cometic will make custom HGs, and as far as I know they'd definitely be up to the challenge. Firgure it this way... If you're going to be building a 12:1 engine for boost, the money it would cost to get a Cometic or somethign similar in there isn't a whole lot. Drop in the ocean kind of thing.
                      1994 Pontiac Grand Prix GTP Special Edition, Black 5-Speed
                      1995 BMW 540i, Alpineweiss-III, 6-Speed
                      1995 BMW 540i, Schwarz-II, Automatic
                      2004 Honda 919, Light Silver Metallic, 6-Speed
                      • timg
                        • Feb 2004
                        • 718
                        I've blown Cometic's headgaskets before...
                        Tim
                        325 whp 350 lb-ft
                        • Husky
                          • Aug 2005
                          • 200
                          Undoubtedly. But I bet they hold up better than standard Fel-Pro gaskets.
                            • 13531
                            Do you have the o ring with the cometic gaskets?
                            • Fierobsessed
                              • Mar 2004
                              • 219
                              Bored and stroked with factory pistons, still only gets me from a stock 9.7 to 10.7 by my math. It increases the displacment about 60CC per cyl witch roughly equals the combustion chamber volume, so it adds 1 whole point to the compression ratio. If you're starting from 9.25, expect 10.25.
