96 Beretta Project
  • geldartb
    The Situation
    • May 2004
    • 1994
    #166
    the only one where you have more duration than me is the exhaust and thats only 7 more. same with your lift but thats 53 more than my exhaust.
    227 233 .050 dur 515 515 lift 112 lsa
    216/240 .050 dur .517/.568 lift 112LSA
    dont ask me how it was done. its like a little kiss nothing to write home about and the valve was fine not even damaged. but those heads are sitting on the shelf now.
    99 Grand Am GT
    1357 cam 227 233 .050 dur
      Yeah, well with those differences I didn't think you would have touched unless you were off a tooth or two on your timing at one point... Or your chain is as stretched as mine, but I know that's not true. and 7* duration is a good amount.
      • geldartb
        The Situation
        • May 2004
        • 1994
        #168
        it could have been something from when it first went together. you remember how it sounded. something wasnt cool but ill never know what that was.
        iirc every time i had the side cover off which was two or three time all the dots got lined up and i started with the 99 stuff from the beginning. even the 05 stuff that was on there only had something like 8k on it.
        99 Grand Am GT
          • 13525
          #169
          Looks like a good article topic to me.
            damn you guys, now i'm going to have to go pull out my cam.
            pics in a little while.
              Suddenly getting bent over at the dealership for bearings doesn't look like such a bad idea. Pucker up!
              • mfuller
                Mr. Common Sense
                • Nov 2003
                • 374
                #172
                Shit.....I had my motor built with Sealed Power cam bearings also.
                Screw it......I'll just drive it until it dies and then have Ben build it bigger and stronger.
                Matt
                  #1 bearing (ouch)
                  #2.. just worn
                  #3, just worn
                  #4 looked fine.
                  guess i'll be replacing these with SBC bearings in the spring...
                  Cam looked fine.
                    And for clarification, those were stock GM bearings, Dave?
                      yep, maybe 3K miles with the cam, around 4K total. stock 3500 bearings.
                      • RedBird
                        Aka Mr. 5th Motor
                        • Sep 2006
                        • 426
                        #176
                        hey, those look just like my old 3400 bearings
                        Cammed 3400 --> 224whp 210wtq
                        Cammed 3500 --> ???
                        1 of 5 3500 J-Bodies
                          the ones with over 90K on them?
                            #178
                            I wonder how my 235,000 3100 bearings look?
                              probably about like mine.
                                I want to clarify that's EXACTLY what my stock 3400 cam bearings looked like after 15k of abuse with my Milzy cam. There was NO pitting like all these sealed power ones have done to me.
                                Little update, here is my porting progress.
                                What I started with and did two years ago to gasket match...
                                This is what I have now, thanks to the insight of Dave and Ben.
                                Still gotta work it a bit more but for the most part this port is about done.
