3400 knock sensor
  • matt26
    • Jan 2009
    • 2
    3400 knock sensor
    hi guys im new to the site hopefully someone can be of some help.im wondering where the knock sensor is located on a 3400 in a 2000 chevy venture.i saw a similar looking one on the base of the engine but just want to be sure before i go pulling it out.thanks in advance
    • 9191
    Welcome. The KS is located just above the starter and next to the oil filter. The OPSU (oil pressure sending unit) is also in that area. The KS is short and wide (~1.5"), whereas the OPSU is slimmer and depending on the gauge config, can either be short or long.
    • matt26
      • Jan 2009
      • 2
      which one is for the ignition? thanks
        • 9191
        Well, a knock sensor has something to do with the ignition, basically to adjust (retard) the timing if it detects detonation in the engine.
