Newb From Arizona
  • Charless1
    • Oct 2009
    • 42
    Newb From Arizona
    Hello All I just purchased a 1989 Corsica with the 2.8l 60*v6. Car is in rough shape body wise. Previous (Original) owner was in a fender bender (literally) Hood is Primer gray Pass Door and fender are Blue rest of car is White. It is the Hatchback. I was searching for forums for the Corsy as I had an issue with the Rad Fan not kicking on. I have already posted elsewhere prior to today and Robertisaar has been a ton of help. What I am currently looking for is if anyone has photos of the Radiator as I have a bypass hose (what the mech at the shop called it) that is not connected to the Rad. They put a screw in the rad right next to the Filler cap where the hose would connect. Need to know if that is a replaceable port or if I will have to replace the entire radiator. Photos would be best for me but any comments are surely appreciated
    • 13531
    Welcome to the site Questions are best posted in the other areas of the site with a matching title. I have no idea what your radiator setup looks like so I cannot help with that.
      if i remember, or if someone reminds me, i'll take a pic of the general area on the wife's 90GP in the morning. it's probably the same if not similar.
      • Charless1
        • Oct 2009
        • 42
        OK I am looking for pics from under the hood of a 89 90 L-body if anyone can direct me in the right Direction. Checked the garage and could not find what I was loooking for there. Just trying to find an image that shows a coolant line that I have no Idea of its actual destination
          If it is next to the cap, it sounds like the line for the overflow tank, maybe. Just a quick guess.
          • Charless1
            • Oct 2009
            • 42
            Not the Over flow it is off the 3port adapter right next to the front Head on the left side
            • Charless1
              • Oct 2009
              • 42
              Here is an image of the area where the line is not very good but I put a Yellow box around it with arrows (Thanks to the original owner of this pic. I hope you do not mind that I borrewed it
