My 89 Camaro Project
  • onefastV6
    • Sep 2005
    • 880
    #391
    Time to do a FWD swap
    2000 Grand Am GT
    2011 Chevy Impala
    • ericjon262
      build it.
      • Jan 2010
      • 2218
      #392
      LAME.
        lmao...
        Trans is fine, rear end is not.
          Time for a TKO!!!
          T56 sounds more fun.
          also DAMN dave..... how you kill a rear end with a V6? the V8 guys will not be pleased. launching with slicks?
          • ericjon262
            build it.
            • Jan 2010
            • 2218
            #395
            TKO is easier, and probably cheaper... did you make any passes on it?
              2 but nothing to write home about, shift cable was mis-adjusted so they were pretty slow.
              oh and Crank case pressure going down the track at WOT stays about 2kpa above the baseline. It's good to know that there isn't any excessive pressure, i'd still like more of a vacuum though.
              • caffeine
                • Jan 2012
                • 1489
                #397
                How much do TKOs cost?
                '86 Fiero, 3500, 4-speed
                • ericjon262
                  build it.
                  • Jan 2010
                  • 2218
                  #398
                  I see them used for about 1K all the time, and IIRC, it's based on a T5, which should make it more of a bolt in and go deal.
                  • caffeine
                    • Jan 2012
                    • 1489
                    #399
                    I decided on a t56 mostly because I already had it. So far the majority of cost in getting it to work has been buying the clutch and flywheel. The sbc adapter is only $70 iirc.
                    6 speeds with 4.11 gears is fun
                      At least it looks like it's a set of spiders and nothing real expensive and a pain to set up like a ring and pinion.
                      • ericjon262
                        build it.
                        • Jan 2010
                        • 2218
                        #401
                        it's all in the chassis setup and gearing.
                        I might have to re-think my rear end choice after watching those vids.
                          Live life 3.7mi at a time
                          • 4555
                          #402
                          Last weekend.
                          4.88 gears, engine is breking up at 6500rpm, usually shifts at 6800, but either way....
                          60 - 1.668
                          330 - 5.027
                          1/8 - 7.899
                          MPH - 85.76
                          1000 - 10.387
                          1/4 - 12.519
                          MPH - 104.48
                          • caseylasater
                            • Oct 2012
                            • 5
                            #403
                            Nice! What does the car weigh?
                            96' beretta - stock 3400 with 3500 top swap with a 5 speed and thats about it.. Oh and a spec stg 4 clutch that slips when i turn the boost up
                            06' dodge ram on air suspension with a basic 3link set up. sold
                            05 cts-v bolt ons and a cam on CCW SP600s
                            • Mars
                              • Apr 2004
                              • 826
                              #404
                              LOL You don't have to post that thing in every "quick" V6 F-body thread... just start your own thread.
                              • ericjon262
                                build it.
                                • Jan 2010
                                • 2218
                                #405
                                esp considering it has a 3800... lame!
