Roberts 89 GT/U build 3400/3500 WOT-Parts
  • robert 1980
    • Aug 2009
    • 302
    #31
    The headers are also getting re-coated and should be finished mid-week=)
      I normally use a razor blade laying almost flat along with brake clean and compressed air.
      • TGP37
        Shadetree Engineer
        • Jul 2011
        • 1027
        #33
        I do that too, razor blades. I use the thinner square blades. They wear faster but they do not damage metal as much as the stronger blades for tool knives.
        They also have plastic razors which are really neat for soft aluminum. Find them in a paint store.
        I also tried magic erasers and they work pretty well.
          That's a neat idea, I never thought of that one.
          I also got one of those buffing/polishing kits for a die grinder from Harbor Freight and the 3M like pads worked really well for taking gasket material off, but the polish swirls gave me the impression that metal was being removed, so I'm kinda apprehensive about using them again.
            • 13525
            #35
            Never use steel wool or the scotchbrite pads on mating surfaces (aluminum). If you want something machine shops use, get the 3M bristle disc setup. White and yellow are milder than the green ones.
            • TGP37
              Shadetree Engineer
              • Jul 2011
              • 1027
              #36
              That's actually good to know.
              Next time I tear into the block I'm gonna get some of those, thanks.
              • TGP37
                Shadetree Engineer
                • Jul 2011
                • 1027
                #37
                I bet your excited. Your ride is gonna be reborn again.
                • robert 1980
                  • Aug 2009
                  • 302
                  #38
                  New clutchmaster stage3 clutch.The getrag had 77xxx miles when i purchased it and my buddy and myself did a full rebuild and installed a ep LSD.After the build is finished im going to get a set of slicks and call it a day.Im really excited to have a 13 second N/A car very soon.lol
                  • TGP37
                    Shadetree Engineer
                    • Jul 2011
                    • 1027
                    #39
                    How do you like the getrag (282?) with the LSD? I've just barely started to drive mine here and there. Big difference from the automatic
                    • bob442
                      Show Me Your KITS!
                      • Nov 2008
                      • 1305
                      #40
                      as long as you can make the shifts lol
                      • robert 1980
                        • Aug 2009
                        • 302
                        #41
                        Yeah i've had this car for almost 9 years.And i've but over 150xxx miles on the 2.8
                        And another 30xxx on the 3400.In that time i've missed maybe 3 shifts.
                        Onces was because i was sick from the night before and i was puking while driving.lol
                        Yeah the car came with a 5/speed i love a stick shift cars alot of fun on the street.
                        With the LSD from Ep you can really feel it hook.even in the rain well the one time i did drive it.
                          Been a little busy lately, but Ben said he's going to try to get the rings drop shipped to me from Total Seal, crank scraper is on the way and I'm going to get some other stuff done on the car while the motor is waiting for parts, like spray a little paint in the engine bay and such. I also hope to get the heater core pipes and fuel lines soon from a Bnet user.
                          Robert the clutch did show up last week I forgot to tell you that. I was about to return it till I saw the tag stating it had been bolted down for testing purposes since I could see where washers had removed paint, I was like WTF its used? LOL. It looks good and I'm just simply amazed at how little clutch material will hold power...
                          • TGP37
                            Shadetree Engineer
                            • Jul 2011
                            • 1027
                            #43
                            "I'm just simply amazed at how little clutch material will hold power" - I thought the same thing when I received my Spec 3 Clutch. 6 Puck design good up to 500 hp. Amazing, 12 small little areas where all the power is transfered through.
                              This appears even less than a six puck... That at least has 6 little pads... look at what a Clutchmaster Stage 3 looks like.
                              The light tan is the clutch material, NOT the dark brown.
                              I think I'd be happy with the FX200 for my Legacy
                              But $625 is insane... I can get that price from Fredbeansparts.com... Clutchmasters wants $735 direct.
                                Forgot to post what happened to his spec stage 2+ clutch.
                                Flywheel
                                Pressure plate
                                Disc
