Multiport coverted to carb!
  • runinoutofgas
    • Dec 2011
    • 6
    I have converted a couple mutliport engines to carb and hei distributor, i want to put pics up, could someone help me with that????
  • runinoutofgas
    • Dec 2011
    • 6
    Here ya go
    What you think??
      • 9191
      First off, welcome to the site.
      Secondly, looks very interesting! Any reason why you put the carb up on such a raised box instead of closer the the plenum top? Seems like you'd have much better clearances. Will that even clear any kind of hood?
      Brad via Tapatalk
        • 13531
        • 2.8-350TBI
          RWD FTW!!!
          • Sep 2009
          • 350
          I spy two of these upper plenums. A 2.8 and a 3.1 plenum
          Originally posted by Mars
          Haha ^ Wrong Wheel Drive.
          No 60ºV6 at the moment
          • unchained01
            • Jan 2011
            • 388
            just when you thought you had seen everything
            • runinoutofgas
              • Dec 2011
              • 6
              The box is for throttle clearance, i doubt it would clear the hood with carb flat on the plenum, these setups are for derby cars,(shoulda mentioned that). Although i want to take the next one to the drag strip before i gets smashed cuz these buggers scream!
              I also got a pipe dream of using a w body(lumina) subframe with one these setups on a ratrod someday. Probably use a 3100sfi for that though.
              • unchained01
                • Jan 2011
                • 388
                I thought they might be for an open class dirt track car or run what you bring class roundy round beater
                  lol, this thread made my day.
                  • RocketFast321
                    • Aug 2006
                    • 4
                    Why a little 2bbl q-jet? Put a 4bbl 750 q-jet on it and see if it holds together.
                    EveryDay: 2001 Alero 2.4 5-speed
                    Hualer, Mpg? ROFL: 1984 Buick Electra Estate Wagon Fresh 3oh7 268h camming. OEM 84 2004r
                      • 13531
                      A 750 would have no velocity. A 440 is probably a bit much for a gen 2 but for a 3500, it is what I would start with. I wouldn't even consider it by modding an upper though, only a lower.
                      • bob442
                        Show Me Your KITS!
                        • Nov 2008
                        • 1305
                        A 750 would turn that motor into a giant fuel pump LOL
                        • runinoutofgas
                          • Dec 2011
                          • 6
                          Trust me the two barrel is plenty and can raunch these motors, specially with no rev limiter
                          Sappy: how would you go about modifying the lower? Getting something machined? I have often thought about putting old iron heads/ intake on a mpfi engine anyone tried that?
                          And if anyone considers doing this i would suggest gettin the plenum and lower intake runners steamed out.
                            • runinoutofgas
                              • Dec 2011
                              • 6
                              ^^^WOW!!!!!!
                              I want one! They for sale at all??! Looks like alot more clearance for a distributor.
