In Depth pics of the 3.6L Global V6
  • geoffinbc
    Iron Head Enthusiast
    • 5831
    Full cutaway and component views. Check out that crank!
  • RidgeRunner
    • 971
    Wurd... that's a beautiful thing.
    60v6's original Jon M.
      • 13525
      I have all the pics from the 3.6 DOHC in a zip file if anyone wants it. Its 34.4 megs but has 64 pics, all FRICKEN HUGE! hahaha
      • Guest's Avatar
        where can i get pics like that of the 3100 SFI V-6?
        • z284pwr
          • 88
          Oh oh, me me me....... .....34.4 megs is weaksauce....
          Oh I don't suppose you've got some of the 3900 too in the HUGE size? I'm all about the biggest size possible.
          Brian Edwards
          '73 Trans-Am
          '79 Suburban
          '90 Beretta INDY
          '90 Turbo Grand Prix
          '04 TSX
          '04 TL
            • 13525
            I dont have any of the 3900 but I saved all the pics I could find of the 3.6. Ill upload them to the site since we have about oh....a shitload of bandwidth to burn through:P Its uploading now, and that takes a while.
            http://www.60degreev6.com/download
            Says it will be up in about 30 minutes from now.
            • 93LuminaZ34va
              • 144
              hmmm.... that 370hp version sounds a bit interesting to me.....
              1993 Chevy Lumina Z34; 4T60-E, CATCO 2.5" hi-flo cat, Flowmaster Exh, American Racing Aero Rims, KYB GR-2's
              1999 Tacoma SR5 TRD 3.4V6 4WD, lift, tires, rims, exhaust, couple of tricks
              1962 Buick Electra 225 STOCK... and gonna keep it that way
              • Lyle's GTP
                • Jan 2004
                • 1345
                Why do so many manufactures use the rocker system and not direct cam lifter set up? Isn't it less efficient, More moving parts?
                Lyle
                • geoffinbc
                  • 5831
                  You need the rockers to increase the ratio. How else do you turn a .200something lift into a .400somethig? If there were no rockers then the lobes would be huge.
                  • Cliff8928
                    • 532
                    That kinda makes sense... it also allows the manufacturers to make the engine a little shorter, not having the cam directly over the valve and lifter. It's possible some way that it's lower friction aswell? (just guessing on that one)
                    Cliff Scott
                    89 BerettaGT
                    89 Volvo740 <-DOHC, no rocker-arms
                    Cliff Scott
                    89 BerettaGT
                    04 AleroGX
                      • 13525
                      the 3.4 DOHC has no rockers:P Their weight however makes me wish it did have rockers and thinner lobes/lifters. Oh well, it all works.
                      • z284pwr
                        • 88
                        Thanks for the pics....oh and nice server, constant 650 k/sec makes me happy
                        Oh and I now know what you mean by "BIG" 3000 x 2400, that is wallpaper material....
                        Brian Edwards
                        '73 Trans-Am
                        '79 Suburban
                        '90 Beretta INDY
                        '04 TSX
                        '04 TL
                          • 13525
                          That is the fastest rate im aware of so far I found the files I had cut down to a reasonable size, and zipped they are just under 5 megs. If anyone wants all of them but is on dial up, I can upload it as well. I think they are 1024x768.
                          • Lyle's GTP
                            • Jan 2004
                            • 1345
                            The problem with the 3.4 is the cams and cam carriers they are absolutely hugh, way over designed, they completely and totaly dwarf any other DOHC V-6 and you can quote me. You will never have to replace a cam when you rebuild.
                            Lyle
