Add 80hp instantly
  • phantomgreen
    • Dec 2006
    • 78
    Add 80hp instantly
    Hey I was just checking out some performance parts for my dads truck and was looking at the Upgraded ECMs. they add up to 80 hp and 160 tq How sweet is that. Ben, why cant your chips do that? Jk
    http://www.ssdieselsupply.com/produc...raded_ECM.html
    • 13531
    bullydog performance makes a lot more than for the the diesel trucks. Hard to compete with boost chips for numbers:P
    • 85_305
      • Feb 2007
      • 350
      Bullydog is nice.. overrated though. They charge so much because.. well.. they can.
      '93 Sunbird. 5spd, 3.1, it's fast. Oh, and 240k miles has proven lethal against Turbo Talons
      I'm lurking occasionaly. It's tough because I'm usually too busy with the Army or my 5.0 Mustang. Which is for sale.
      camaromanmatt@yahoo.com
        • 13531
        I read about them in performance business magazine. Overrated? I dunno unless their dyno numbers aren't accurate.
        • 85_305
          • Feb 2007
          • 350
          Oh they are very acurate numbers.. they live up to their exptecations.. diablo sport is good. And so is Banks. Banks, in my opinion, is the BEST bang for the buck. With the 5" exhaust, programmer, cam piece, upped FPR and fuel pump, you are making OVER 1500 lb's of torque. Add in level three injectors, your pushing 2000 ft/lbs and 1k hp.
            • 13531
            All I care about these days are MPG numbers:P
            • 85_305
              • Feb 2007
              • 350
              Well w/ all those mods I mentioned, it would only increase gas mileage on a diesel. I know of 1200+ft/lb to the WHEELS diesels grabbing 25mpg+.
              • StudlyCamaro
                • Nov 2003
                • 692
                www.cleanmpg.com ... thats why i havn't been around here as much recently
                3.4L camaro some goodies
                • scrappy
                  • Oct 2005
                  • 53
                  you are overratting just a little(ok, a LOT), no diesel with a stock turbo and injectors is going to make that kind of hp/tq. And Banks is an overpriced joke, I wouldn't touch their electronics. their hardware is good but overpriced. There are other companies that make better Hp #'s for less green. I do happen to own a diesel so I know what I am talking about.
                  Diesels are easy to turn up since they are severely derated from the factory in most cases. Diesels are rated at what they can run wide open full load all day long w/o failure. Mine is dyno proven at 457/1002 with all stock internals. All I have so far is 2 boxes stacked, intake/exhaust, turbo, and pusher pump. With injectors and a modded high pressure pump I will be close to 600 hp.
                  I am now at the point that parts are expensive, just having my injectors rebuilt with 100 hp tips is going to be $1700!
                  White '89 Beretta GTU with a 3400 under the hood. only a tranzgenic CAI so far!
                  • RednBlack
                    Wood Hippie
                    • Mar 2004
                    • 2795
                    Originally posted by StudlyCamaro View Post
                    ..thats why i havn't been around here as much recently
                    I thought it was because your girlfriend died. My bad...
                    • OldSkoolGP
                      That guy over there
                      • 930
                      Diesels can make such extraordinary numbers because they are turboed,and it's almost impossible to run them lean. And because everything in the motor has to be made of steel they're very tough.
                      • scrappy
                        • Oct 2005
                        • 53
                        THEY ARE LEAN BURN ENGINES! that is why they get such good mileage. A diesel engine is fuel throttled, they only get enough fuel to maintain the current rpm. a properly tuned diesel will not smoke in a steady state condition and will only smoke a little if at all when they are trying to accellerate. if it is smoking it is considered overfueled and really isn't efficient since it is sending partially burn't fuel out the exhaust. Diesels can see such large improvements since in most cases they are severely de rated from the factory. also when you increase the fueling to the engine it creates more boost.
                        • geoffinbc
                          Iron Head Enthusiast
                          • 5831
                          EGT is you first limiting factor. Then mechanical destruction. You can make power until you find a breaking point.
                          There is no need to worry about detonation, octane rating or spark knock when under boost.
                          • scrappy
                            • Oct 2005
                            • 53
                            EXACTLY!
                            • StudlyCamaro
                              • Nov 2003
                              • 692
                              , I swear you have the best sense of humor of anyone on the internet! [/flirting with another man] ( <-- now that made me laugh)
