i had both front hubs go out at around 110000 the pasenger side went out first shortely followed by the driver side
Is this normal?
1994 Cutlass Supreme Convertible 3.4 DOHC
1969 Oldsmobile 442
1997 Chevy Tahoe
http://members.cardomain.com/mperkins442
I always watch what the guys at Discount Tire do when taking wheels off, or putting wheels on any car I take there. The only thing I don't watch them do is fix flats, break down a tire, mount a tire (boy am I glad I don't watch another guy mount a tire, lol), or balance them. I am not saying I don't trust them because I have had pretty good service from them every time I go there. I just want to make sure things get done right!Originally posted by Lyle's GTPI took my car in a couple weeks ago after I had a flat, the Kaltire, bastards didn't even tighten the lugs. I drove 40 blocks and once I got into the river valley and picked up speed I could feel a vibration. I was only 2 blocks from so home I pulled over. All the lugs were loose like not even impact tight let alone torqued, we're talking only a couple threads.
Took it back and didn't even get an applology, the fucker say's "that's why we have disclaimer, it happens all the time". The disclaimer reads: that you have to bring your car back in within 100km for a retorque. As if I over ran the 100Kms or something. I straightened him out. Told the fucker, 40 blocks or 7 minutes ain't no 100 Kms. Made him let me watch his guy torque them to 100ft/lbs. I will be watching every time from now on.
Lyle-60v6's 2nd Jon M.
The front passenger side one on the 91 wiggled some. The sound it made, I thought the caliper mounting bracket bolt had come loose again. When I took the hub off the car, when I put it on the ground, it split apart. Splitting apart as in the hub part that the lugs goes into came right out of the bearings. Not good, so you had better check that out before you go flying down a mountain side, literally, lol.Originally posted by RidgeRunnerHmm... I have 196k miles on all four original hubs. But I think my fronts are starting to wiggle a bit.-60v6's 2nd Jon M.
Yeah, just to think that came off an Autocross car (90 GTZ)... Luckily it was before it was put into use as such.. (that pic is when we were installing the KONIs and the sport springs)
Cliff Scott
89 BerettaGT
89 Volvo740Cliff Scott
89 BerettaGT
04 AleroGX
Yeah, exactly like that one, lol.Originally posted by Cliff8928much like this one?
Cliff Scott
89 BerettaGT
89 Volvo740-60v6's 2nd Jon M.
My 91 GP lasted 17x,xxx miles for both fronts. Rears are still original but i hope to sell the car before I find out what they will do.Ben
Remove wheel, brakes, remove spindle nut and push spindle out of hub (3 jaw puller works for me), remove bolts holding hub to knuckle and replace... I don't think I forgot anything, other than the obvious like jacking the car up.
60v6's original Jon M.
