3.8 supercharger in alero
  • scoopy03
    • Jun 2007
    • 53
    soon i will be doing the swap over into one of my aleros. i already have the ecm and bcm. i am getting the wiring harness soon. the swap will probably be done in the winter time most likely since i will be probably broke until then. any comments or how to go about this would be appreciated. i already looked pretty far into this already as far as the driveaxles going in no problem. the swap is engine and tranny complete series 1 from a 1995 buick park avenue ultra. somebody told me i have to use pinouts from the alero or something like that.
    Planning on doing 3800 Supercharged swap soon in either my 4cyl or 6cyl.
  • Guest
    You'll probably want to post this on a 90* or Alero specific board. This is a 60* board and most of us have little to no experiance with the 3800, at least when it comes to swapping them in.
    I believe these links still work:
    There's an Alero board that I can't think of the URL for....
    • PCGUY112887
      • Feb 2006
      • 1067
      ECM and BCM? Aleros are GM cars... they use PCM's.
      SpudFiles
      Theopia
      Enjoy life online.
        My cars have ECM's.. not sure about yours :P
        • 3100 MPFI
          • 1522
          The Alero has a BCM, but it is the BODY CONTROL MODULE. Every electronic thing on the interior is controlled by it. Might have to swap one in to get the engine data to interface with the gauges.
          Keep in mind that the Grand Am, and Alero BCM is the weirdest setup I have EVER seen.
          Taylor
          1998 Lincoln Mark VIII
          • scoopy03
            • Jun 2007
            • 53
            ecm and bcm are from the buick.
            • DEI37
              • Jan 2004
              • 516
              I'm not sure that swap is worth it. You're not gaining much. That is a Series I 3.8 SC, and only makes 205HP and 240 ft lb of torque. While that is a big improvement over the engine in your car, the better bet would be a 1998+ L67. It starts with 240HP and 280ft lb of torque. Plus, there is an aftermarket for it, unlike the Series 1 engine. I'm not sure which car to advise you to get one from, since you're going in to an N-body car. But, W-body electronics would work best, GP GTP for the PCM. The engine would probably be best sourced from a W-body as well.
              • scoopy03
                • Jun 2007
                • 53
                well some of the "flaws" up here around me are the 95 supercharger engines are all day long now that i have the 95 one. plus anyways i got the engine and trans complete for well under 500 for engine and trans that have only 60k on it the car was hit it the rear it was a perfect reason to pick up this engine and so i did. 1998+ L67 would be nice there are a few here but i dont have the money they want for it because they sell accesories and all parts of the engine for cheap but when they have blower or supercharger it is like 3x more expensive. the swap would be well worth it in the v6 since it always runs hot regardless if it freezing out or 100 degrees outside. my current 3400 has enough problems with coolant leaking (fixed almost completely without having to do gaskets yet). also it would allow me to give the car the well needed attention since it could use better suspension as it is and the gas mileage hasnt been the same since i got it with 35,000 miles like 3 years ago (atleast 70,000 miles right now one transmission later engine will be next i know it)
                already have:
                95 buick park avenue ultra engine/trans
                pcm (ecm whatever u want to call it), bcm
                need:
                wiring harness
                to pick car for engine to go in
                better suspension if goes into 2001 3.4 alero
                • scoopy03
                  • Jun 2007
                  • 53
                  im seriously starting to consider the v6 alero when i plan to do the swap. it would solve the problems im having with the 3.4l although the 3.4l has beaten many cars by surprise one of the best "kills" was a z28 that said he ran 13s
                  • scoopy03
                    • Jun 2007
                    • 53
                    well 205hp and 240 ft lb of torque in a 3,800 lb car mine will be at like 3,300 so it will be be slighly higher not much but still. maybe 215 and 250 or something like that (fast calculated estimate) couple mods and 13s all day better than my 14.9 best cant find slip though well i ran 15.4 with bad trans. and bad suspension got 2.39 60' best was 2.3 i can name so many pluses with the 3.8 SC engine than i can with my current 3400
                      • 13496
                      ugh...
