new myth?
    • 13517
    new myth?
    So this is that 95 DOHC jackass posting on the pontiacpeople forum. Have fun with it, cause its a winner.
    Zedo
    Administrator
    flow numbers are for 3400 pushrod motor, not 3.4 DOHC
    HEADS UP, GUYS:
    I've been informed through the grapevine, indirectly from the guy that did those flow numbers, that they are for the GM 3400 pushrod motor, not the DOHC- both engines share the same 60 degree block to my knowledge, but different top ends- for some reason he insisted on telling Lou, to try to "get me in trouble", for posting "incorrect information" on our own site. All he had to do was tell me and I would gladly pass that info on and correct it, like I'm doing now. This kid seemed intent on trying to ambush me by "proving me wrong" or something. WTF ?? (laughter...) I think someone has to put down the hash pipe and video game remote...
    Yet he drives a Honda, and it's like a 16 second car- these guys argued with me, and got all bent out of shape, telling me I should not disconnect my EGR valve from my engine- telling me to save the environment and s-hit like that. So you make the call...
    at this point, I'm thinking, perhaps the flow numbers were taken with a vacuum cleaner, who knows...I believe he used one of those "quick flow" attachments for a vacuum cleaner, the intake ports on those heads are only 111 cc, so I'm starting to SERIOUSLY doubt the flow numbers now- my radar went off. The flow numbers are not from the best source, so tread cautiously at this point.
    lesson learned...
    anyway, this leads me to suspect, the DOHC V-6 heads may flow even more !
    • 13517
    So the intake ports being 111cc means they can't flow? MYTH: You can compare pontiac 1960-70s V8 heads to GM 60V6 heads made in the 90s.
    False. The cc measurement is going to be more if you have 6" of runner in the head! The 60V6 head is missing the valve cover gasket area...cause the rest of it is part of the lower intake manifold.
    Myth: A honda elite SR 50 scooter runs 16s in the 1/4.
    False. It probably takes 25 seconds+ but thanks for your enthusiasm in scooter performance.
    Myth: I use quick flow attachements on a vacuum cleaner to come up with flow numbers used on the site and store.
    False. I use a proven setup with vacuum motors. My bench is rated within 5% of industry standard superflow bench testing. Proven 3% in testing. Proven 1% repeatability.
    Myth: Removing the EGR makes HP on a 3.4 DOHC
    False. The EGR is not open at wide open throttle so that doesn't matter. The EGR is also tuned into the ECM to adjust spark and fueling based on the % it is open. While removing the crude EGR devices of the late 70s may have made a noticable difference (probably from rejetting/timing the motor too?), it takes more than a ratchet and socket to correctly disable/remove the EGR.
    Myth: I know more than you cause I was doing this when you were in diapers.
    Huh? Quality or quantity...you obviously aren't too intelligent if you have to pull that bullshit card every time someone disagrees with you.
      • 13517
      "anyway, this leads me to suspect, the DOHC V-6 heads may flow even more !"
      You gotta be joking. REALLY! So you think they outflow the 3400? You should write a book.
      3.4 DOHC flows 150-200% of the 3500 from .050-.250 lift. I blew through them and wrote down what I felt they flowed.
      • Darin
        • May 2006
        • 259
        Im speachless, Actually laughing so hard I cant breath....
        What a tool!
        1999 Grand Prix SE 3100
        1997 Dodge Ram 1500 4X4 Ext cab. 5.2L
        1977 Dodge Power Wagon, Short bed, Fuel injected 360, 4spd, Dana 60's, Little Red Express bed.
          Live life 3.7mi at a time
          • 4555
          The link didn't work for me, but is the same guy who was giving shit to Brad?
            • 13517
            Yes, same guy.
            Last edited by SappySE107; 06-25-2007, 08:20 PM. Reason: removed link to their forum
            • Ajaxus
              Damn
              • May 2006
              • 31
              I'm glad I began reading these forums again around the time this drama began to surface..I need entertainment on these boring night shifts, lol
              MyG6.com Admin
              • sprucegagt
                Old School KI
                • May 2005
                • 703
                I say if they are too stupid to check the GM part number listed on your flow sheet, then let them suffer from their own stupidity. That admin(zedo) is an obvious idiot and hypocrite.
                Your local OBDII moderator
                2000 Grand Am GT w/ WOT parts
                • blackbombshell95
                  Kaiō-ken X 10
                  • Jun 2004
                  • 1386
                  Ben, you should try out for the tv show Myth Busters.
                  02 GTP - 90* > Failboat
                  www.blackbombshell95.com
                  • OldSkoolGP
                    That guy over there
                    • 930
                    If you put a bouret and glasses on him, he kinda looks like Jamie Hyneman!
                      I feel dumber now.. thanks
                      It's amazing how narrow minded some people are.. just oblivious to anything outside their little world... Kinda sad really...
                      • Dohc Holiday
                        Banned
                        • Jun 2007
                        • 2
                        I got banned cause I told the admin to fuck off. I then proceeded to repeat the ignorance of before.
                          • 9186
                          You might as well just leave now. Why? Something to ponder...
                          Your IP : plns-209-74-29-79-pppoe.dsl.plns.epix.net
                          IPs used by the other guy :
                          plns-216-222-249-201-pppoe.dsl.plns.epix.net
                          plns-205-238-250-46-pppoe.dsl.plns.epix.net
                          So either you are the same guy, a relative of the guy, or a local friend of the guy. I really doubt that you are just some guy that wants to defend him and you just happen to live in the same area.
                            Owned...
                            and 16 sec cars? Please..
                            • Ajaxus
                              Damn
                              • May 2006
                              • 31
                              this made my day
                              MyG6.com Admin
