Somebody Stole My Revised Addco Sway Bar!!!
  • blackbombshell95
    Kaiō-ken X 10
    • Jun 2004
    • 1386
    Where Did It Go!
    02 GTP - 90* > Failboat
    www.blackbombshell95.com
  • PCGUY112887
    • Feb 2006
    • 1067
    I bet Ben stole it!
    SpudFiles
    Theopia
    Enjoy life online.
    • dohcfiend
      King Chalupa
      • Jan 2004
      • 2351
      *whistles innocently*
        • 13534
        Yeah, I hired the UPS guy to take it:P I really don't know what car to put it on or when I will be doing so. It came with bushings too
        I was going to post it up in our buy/sell/trade section just to fuck with you though. I still can't believe you gave me a sway bar setup.
        • bve32k
          3.4 DOHC FTW
          • Jun 2005
          • 475
          hahaha. You were talking about buying one a while back. You better pick what car to put it in!
            • 13534
            Well, ill put it this way. The 96 GTP is nicer looking, handles better, brakes better, and only needs a hood to be rust free appearing. Downside is I need to replace just about everything in the rear end underneath if I want to make it how I want it.
            The 91 SE is my first real car (the le baron convertible doesn't count as it topped out at 74mph). I have modified a 3.1 motor/rebuild, swapped a 3.4 DOHC 5 speed in, and now its empty. I have a 3500 on the stand and with 3.6 DOHC pistons, I can have 14.55:1 compression. Using 3400 heads I can get 16:1. I really want to try 14.55:1 because everyone thinks its going to blow up. The starter will be an issue as well. The 91 body wise is solid. No rust underneath cause I took care of the car, koni rear struts, kyb fronts I think, new rack,radiator, subframe bushings, and nice 2.5" single. Paint is peeling and there is rust on the rear fenderwells.
            Also, there is the 95 cutty convertible. It doesn't run yet (well it does but there is no OD and and its all in rough shape). Also the 94 cutlass I am trying to sell. It needs struts and I have to pull a strut off anyway to install the bar (from what I have read). I don't know why id install this on a car I want to sell though.
            If this was for a 74 cutlass, my decision would be easier.
