60DegreeV6 Clean Diesel Engine
  • 85_Olds_Ciera
    • Aug 2007
    • 259
    General Motors has debuted a new 2.9-liter V6 turbo-diesel engine, destined to find its way into the 2009 Cadillac CTS.
    The V-6 engine management system enables optimal fuel economy as well as reduced emissions and noise by using a recently developed combustion control technology. Key enablers of the system are high-speed, piezo-resistive cylinder pressure sensors that are integrated within the engine glow plugs. These specialized sensors acquire real-time data from the combustion process, enabling instantaneous fine-tuning of the fuel injection process. In the future, this clean combustion control technology will be introduced in other GM Powertrain diesel engines.
    The high-pressure, common-rail system provides up to 2000 bar (29,000 psi) injection pressure. The injectors are quick-firing, piezo-electrically actuated, allowing up to eight injections per engine cycle. The aftertreatment system includes an oxidation catalyst and a particulate filter that are close-coupled to the engine to achieve future emissions standards.
    An electronically controlled variable geometry turbocharger generates boost pressure. The engine has a torque of 550 Nm (406 lb.-ft.) beginning at 2000 rpm, while providing effective fuel economy and reduced emissions.
    • 13531
    Yup, I know this was posted before. Josh has to swap this into his vw.
    • 1988GTU
      LB62LHObbqftmfw
      • Nov 2005
      • 2475
      Look at that Alt... Reminds me of the tdc 3.4's.
        It's externally balanced.. strange.
        • 85_Olds_Ciera
          • Aug 2007
          • 259
          Yes, it was posted here on 03-06-2007, 12:13 PM, but I wasn't on forum then.
          GM diesels are coming, btw....its the future.
          • sprucegagt
            Old School KI
            • May 2005
            • 703
            How so? A number of engines are externally balanced.
            Your local OBDII moderator
            2000 Grand Am GT w/ WOT parts
            • MidnightriderZ24
              • Jan 2005
              • 699
              especially diesel engines..
              [SIGPIC]
              12.268@117... 11's to come!
              • geoffinbc
                Iron Head Enthusiast
                • 5831
                Hmmm Future swap for my new Trooper. The only way that would be possible is if GM makes a standalone ECM or if someone hacks the stock one really well.
