#100 glass bead
    Live life 3.7mi at a time
    • 4555
    #100 glass bead
    Got #100 by accident, but used it anyways, turned out nice...
    Here's #6 IIRC...
    I like #100 better!
    • 19Cutlass94
      • Apr 2005
      • 770
      I like #100 better!
      x2! that looks really good!
      3400/Getrag 284 5spd
      350/NV3500 5spd
      2014 Chevrolet Malibu LS
        I like #100 better!
        X3
        • Scott_68B
          • Nov 2003
          • 147
          I have a stupid question but what would using sand as the media look like? I have a siphon blaster that I've been thinking about using to clean my UIM with.
            • 4555
            Looks like sand . That's why people call it a sandblaster - don't ever use real sand, though. I get mine from Southern Tool, it's an industrial supply store (you more than likely have a MSC, they are in most towns).
              • 4555
              Works good on heads, too (these will get hit again after porting)...
                I have bought some black silica sand from Menards before. It was called Black Magnum, I believe? Ran around $5 for a 25 lbs. bag IIRC, and has a small opening with a flap in it to keep the sand in the bag, yet let you stick the siphon tube in it. I have a siphon tube type blaster too.
                  • 4555
                  I have a cabinet, just dump it in there after vacuuming out the old stuff...
                    Well aren't you Mr. Fancy pants! :P j/k, lol. I want a cabinet, but for now my siphon feed works. Ideally I want a clamshell style, but right now I can't swing it. My post about the sand and the bag of it was pointed more towards Scott, but can apply to anyone since I thought that sand was really good. I don't know what grade it was, but it cleaned surfaces up really really nice. I think it was probably a little too coarse for critical gasket surfaces like the head gasket mating surface though. Worked out really well for things like intake passages and cleaning heads in general, though.
                    • Scott_68B
                      • Nov 2003
                      • 147
                      Yes , what I was wondering is what would the manifold surface look like if I used sand as the media rather than glass bead? Why shouldn't sand itself be used? I have a bucket of it sitting here now and a LIM and UIM that could use some attention.
                      Thanks!
                      -- Scott
                        • 4555
                        The cabinet is not fancy, it uses the same siphon gun you have . Mine is actually very similar to the Harbor Freight cabinet, but mine is 1" thick plastic instead of metal.
                        Sand will just disintegrate and turn to dust. I had someone tell me they could use sand, so I brought a bag of play sand from Home Depot to the shop, and laughed my butt off at the conditions following.
                          • 4555
                          Glass bead is $25 for a 50lb bag, and lasts a long time.
                          • ikessky
                            • 614
                            I have always heard to avoid using sand because the silica can cause some nasty respiratory issues.
                              • 13531
                              so does glass:P
