Thanks to Ben and the 60* store.
    I know its got more in it but right now I still owe the 60* store a thanks, and Ben for doing a sim and getting this cam pushrods and springs to me, because honestly its been surprising me every bit of the way, because honestly the valve train is all thats done to this motor... Cam/springs, 3 angle valve job, gasket matching, 65mm TB, and headers... thats bout it.
    It took a little while to get the car to do what it should do, but that was mainly due to tuning and whatnot but now that I have that dialed in more its running great.
    Hell I drove it to Epping Dragway this last weekend... 2hr ride there at 6am, got there unloaded everything and in about 1 1/2 hrs I was already being called to the track, run one was a 14.177@96.64 Weighed in at 3120lbs, so I lightened it up by removing some other stuff, got it down to a whopping 3070. Following two runs were a 14.983@98.61 and a 14.961@98.39... I don't like the right lane...
    I bring the car back around because the ABS light is on, so I start looking and find out I blew the fusable link from the alternator, so I make up a wire to run from there to the battery for the rest of the weekend... problem solved, voltage fixed
    Go back around in the left lane and hit the sweet spot,
    r/t: .078
    60': 2.091
    330': 5.883
    1/8: 9.006
    mph: 79.04
    1000': 11.699
    1/4: 13.996
    mph: 98.06
    That was the ONE time I got the street tires to hook up enough to pull a good 60' time. Few more runs after that, 14.200@97.98 14.116@97.84 14.082@97.67 2.26 2.23 and 2.12 60' times in the same order... so yeah thats where my issue is.
    I then drive to the hotel, and the go out for Mexican, Get asked if my car is a Honda by all the spanish guys at the restaurant, and if I was selling it... LOL... I then go to the hotel and give me and the car its much needed rest.
    Following day, First run right out of the box at 10am fresh track, they wanted us to warm it up for the event that day, 14.091@97.53 2.13 60' Then swapped over to my ported 3100 upper intake to see what happens, 14.163@97.45 2.15 60' so no definate answer on which one is currently better... Switched back to the 3500 plenum, and got the fastest for the day, 14.006@98.28 2.11 60' and then the last run for the day 14.232@97.04 2.15 60' and looking at the log the car started to run lean, 13.0 a/f numbers, Not sure if its a result of my tank being just above 1/4 or if it's something else going on... fuel pump dying or injectors getting over tasked so they are ready to fail... After that run I quit for the day.
    Stayed at the hotel for one more night and then proceeded to put 140+ miles on the car the following day, going across NH and Mass just to do some driving around, Car drove great that day.
    So all and all I have a decent driveline that can cruse around and leaf peep, and also roll 13's at the strip. I'm rather impressed with this car.
    Car will be getting its final stage of work this winter and be fully painted and show ready... The motor will also be run through for wear, and so will the trans. After a full season of running it hard at 3 different events and spinning the motor in up wards of 6800 RPM I figure the lower end needs to be checked over to be sure nothing is going wrong.
    Next year it will be getting N2O starting with a 50 shot and going up as desired. I think I will also be building a variable delay box for the nitrous system so I can delay it off the line... cheaper to build one than buy one. I think...
    • 13470
    Look out Dave, someone is stalkin you! hahaha, thats pretty bad ass, especially with all 14 flat runs to back it up. More 13 second runs aren't too far off and if you use nitrous...look out. 12s with traction?
      LOL, not on the hunt for dave... Him being a 5-speed I know I'll never get there N/A...
      I just wanted to prove I could make a hybrid a 13 sec n/a car with a 4t60e, and keep it pratical, and affordable. And I've done that.
      Now its time to just have fun with it, make it look good and then make it go a little faster and turn MORE heads.
        I'm at about the same point... i'd love to put on some quiet mufflers and just enjoy driving mine. Too bad winter is almost here
        Congrats on all your hard work paying off. It's always nice to meet a personal goal.
        • geldartb
          The Situation
          • May 2004
          • 1994
          thats the route im going. was planning on it but the inspection kinda speed that up.
          99 Grand Am GT
          1357 cam 227 233 .050 dur
          515 515 lift 112 lsa
          • Rhedalert
            Dr. Feelgood
            • 1574
            Nice times, congrats!
            Brian
            3400 SFI V6, 4T60e
