New Guy! 2.8 blown seeking efi or TBI help?
  • blownarrow
    FWD isn't that cute?
    • Oct 2008
    • 160
    Hello,
    Just joined! Happy to have found this site.. excited to see soo many people
    dedicated to these little motors...
    I'm a long time fan of big performance an a small package. This is my first
    60* v6 I've dealt with and I have to say I'm impressed with the package.
    I have an odd setup and I'm looking to upgrade the fuel delivery.
    I'm running a 89 2.8 with a t5 in a 1977 plymouth arrow/ Mitus Celeste
    N/A the car run and feel nice, but I got a wild hair one day and built a
    blower set up for it! Using a Eaton M90 6-8lbs boost+/- First I due to limited room I ran a Side Draft Weber carb didn't work out to well, hard to tune. Now I'm running a Holley 500 2 barrel and It's runs like a bat out of hell, But I'm still looking for something better.
    I would like to run a stand alone EFI or even a TBI that will support it
    I'm coming to all of you for help.... What should I do? who should I use?
    where can I get it?
    thanks
    jer
    sigpicWhen I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
    • 9191
    It never ceases to amaze me where these engines find homes... Welcome to the site!!
    I guess the first question to ask is, what is your budget? Next question to ask is, how are your wiring and soldering skills? I would say a good candidate for what you are wanting would be a Megasquirt. Do some searching on the site (the standalone computer section of the forum would be a good place to start) and see what you think. Then come back and we can start up a more detailed discussion.
    • geoffinbc
      Iron Head Enthusiast
      • 5831
      What kind of intake manifold is that blower sitting on? Can it accept injectors in the runners? If so this swap wont be so hard you would just need to get the injectors in there and then find a way to put a throttle body on the blower. That would be the majority of the hardware. The wiring and ECM would be the next step after that.
      • blownarrow
        • Oct 2008
        • 160
        The manifold lower half is a fiero bottom and the blowers sitting on a
        plenum I built, as for setting up injectors and building a intake for the throttle body is not the problem.. That's the easy part
        What I'm worried about is a harness and brain..
        • geoffinbc
          • 5831
          Well in that case you have tons of choices. You can go with a modified factory OBDII system, a Megasquirt system or a fancy aftermarket system like FAST or Holley.
          What kind of budget are you working with?
          • blownarrow
            • Oct 2008
            • 160
            Budget? lol
            Actually I'm talking to Justin at Magesquirt now! tryig to put together a
            unit now
            • IsaacHayes
              Mr. Orange.
              • Apr 2006
              • 6030
              MegaSquirt sounds like the way to go on this. Cheap and works with boost well. Get the knock sensor kit while you're at it so you can make sure it won't blow up. Fuel injected and tuned well you will make a ton more power than you are now, and better power band.
              Then in the future you could go to a camaro 3.4 RWD iron block, with 3500 LX9 or 3400 LA1 top end on it for even MORE power. Oh and a cam too. It's RWD so you'll have the traction for the extra power!
              • blownarrow
                • Oct 2008
                • 160
                Why? silly
                I can put that same set up in a 2156-2200lbs arrow
                that's about 1000lbs lighter
                Every 10lbs lost is 1hp improvement and every 1lbs of unsprung weight is 1hp
                improvement.
                In the immortal words of Colin Chapmen "Add Lightness"
                Founder of Lotus.
                Weight of Unoptioned 1987 F-Body Combinations
                Model Base Weight
                IROC-Z 305 5.0 5-Speed 3,250
                Formula 305 5.0 5-Speed 3,383
                IROC-Z 350 5.7 Automatic Overdrive 3,341
                GTA 350 5.7 Automatic Overdrive 3,476
                Weight Data on 1992 Camaros
                Model Shipping Weight Curb Weight
                Camaro Coupe 3,025 3,105
                Convertible 3,142 3,220
                Z28 Coupe 3,194 3,273
                Convertible 3,298 3,377
                • blownarrow
                  • Oct 2008
                  • 160
                  Well like most car geeks I'm looking in all directions when it comes to up grades. And I've stumbled upon a used and inexpensive Holley pro-jection tbi unit...
                  Mega squirt quoted me a nice and fair price for what I'm looking for. But I'm wondering if anybody has had any interaction with the Holley unit? I also found a site that supplies parts and up grades (open to close loop for example) for a nice price...
                  • blownarrow
                    • Oct 2008
                    • 160
                    Well looks like I have picked a unit. I'm going to use a 2nd gen RetroTek
                    self teching tbi set up. Closed loop, self mapping, can handle up 30lbs boost,
                    I've givin a deposit and awating a harness from them to complete the build...
                    • Guest
                      I'd give the OBDI GM ECM a look.
                      I have one running an L28 (inline 6) in my 1973 Datsun 240Z. I have yet to find another ECM that has the capabilities that the P4 OBDI GM ECM has.
                      I'm running a '7749, with Code59, 3 BAR MAP, WBO2 fueling control, Boost control scaled to speed. and many other features, some planned some in alpha testing, currently I'm playing with a knock gauge output, so what ever the ECM is reading the gauge or row of LEDs (which ever type of display is connected) will show the amount of knock retard. Meth/nitrous control is also planned.
                      Tuning is not difficult, software is free or very small donation to get rid of the nag window when using Tuner Pro RT (www.tunerpro.net). There are also products that will allow real time tuning while the car is being driven. These products are supplied by moates.net, there are others but seem to be less refined than moates.net products.
                      The actual ECMs themselves can be found cheap at wreckers, and can be had in under dash units or under hood units.
                      The OBD1 GM ECM also has On Board Diagnostics, limp home mode, and a lot of support through many online communities.
